Grease type for chassis zerks?
I picked up some Lucas Xtra Heavy Duty grease to use on my chassis/steering grease points, but once I got home I noticed it's a Polyurea based grease that's usually not compatible with some OEM or lithium greases. Does anyone know which grease is good to use for a Gen2/2.5 montero, any lithium based multi-purpose?
Toasty
I use a something something moly/lithium something or other. Not sure that's correct, Mitsubishi doesn't have an OEM grease or i'd use that. I also use cheapie guy marine grease when i'm greasing parts to be replaced at a later date.
I use Lucas Oil "Red N Tacky" on chassis and wheel bearings. It isn't their marine line but gets good reviews online, inexpensive, easy to find and people have been using it for quite a while. Admittedly I'm a relative noob to the 4x4 world...
Nice, thanks, I actually got the Red N Tacky when I took the Xtra HD back in to return it a few days ago. Like you said, it seemed to get really good reviews.
mudraider
It's been tested, and the cheap blue tubes at Wallyworld are just as effective as any of the higher priced alternatives out there.
DanoWall
