LR3 Tire Installation
I am going to get tires installed on my LR3 next week and was wondering if there is anything special I need the installers to do because of the air suspension. Thanks
jymmiejamz
If they are doing an alignment, have them drive onto the alignment rack in standard height and then do the alignment with one of the doors ajar so the suspension will not adjust.
As far as the tires go, the only thing to watch out for is the air suspension compressor when lifting (if using a two post lift).
JimBiram
The LR3 isn’t prone to alignment problems if the alignment is done well the first time. Only do the alignment if your tires show unusual wear pattern.
Ok thank you, not showing signs of wear just a nail in one tire and some dry rot. Was going to get tires anyway before winter but the nail just sped-up my timeline.
Henrybrowne
