On Board Water Remote Gauge
jnack
I'm planning a rebuild of my truck bed platform, with plans for a permanently mounted water tank in the rear of my truck (behind drawers). im trying to avoid having to climb in the bed (under camper shell) everytime I want to check the water level and was wondering what sort of options every1 is using to remotely monitor the water level in OBW systems
jnack
A standard fuel gauge float works just fine. Connect it to a standard digital or analog gauge.
more specifically the logistics of that -- installing such a float in a sealed plastic tank without damaging the structural integrity and preventing leaks
Kingsize24
jnack
Lets hope fueltank sensor is compatible with water immersion.
In industry we use a variety of sensors. Ultrasonic, laser, capacitive & so on. Most of those need threaded boss into the tank.
Is the tank wall visible and somewhat transparent ?
Now that video is crazy cheap, how about a camera ?
the tank im looking at unfortunately is not transparent
javajoe79
Fabricator
There are water tank specific senders for gauges. I don’t think I’d use a standard fuel level sender. It would rust
Herbie
Rendezvous Conspirator
Remote mount a clear tube sight gauge?
That's how I did mine when I had a Valterra tank:
d1XYDzI6ILMhsiWG2ryCF8Gdw9LbPzgy0nTpL49AXdJV0lODT0EAfRL4ZWbvFrOOP0iewAE7_yDRbl4P1Btman1UeYZEBCiPmB8FUprO9uoUtGR50ttdMCmfkYXPp-vX0tx6mQPhw9WvSpHB-MuvQ-t8SUk1JpK_1DV3xO-6kHwssuRG7YJ1CNOIiB73MO3a9dggb4iYpqR2WtVS3a4oz7elCPOZ5cudrEOyJN4jhEMT-okjenkBDSB2fP7OJ0_ZPAc-YaS4sSkR_b8jui3vdxew5RThTdd3_AxjJwxQxZsDtEDFoDvwisP1DpvPI2YE8Ob5onj-zbgm8ZHlMi_I786ZjXiH3ddrDiWms_z7ZXWRqnpncU9doyjv1VN29FIAiho0QMXCfTrp8txzm1ODdO495xDGKS14uYr3-orks_h3UQrQk0PuwZf0Yp0Wi1OiKiZDVDni_8dKKDjhjiskNnyWf2IaKARfVnT6BRsjSdo0_GyF-FHKrxZZZCLVMmN8uX_RExFm1imz4QCOMPKxBUbNgvOygXP-fKykSIvo938K9kjRESxNV__A2eYt0X6bsEyRqZJnbkldOzHQT4hAeIYKqxuf0Os-R2XGNWQzjAcMIjskUrJ61S0Mu6TSUqF8Qv7O5GcEBzpSaGfgkUaF07INFlOgayaDwA=w500
I even measured filling from empty and added gallon-specific markers.
jnack
clever. unfortunately for my build the tank will not be anywhere with line of sight to the tank, so i would need a true remote gauge...
Scoutn79
Look at RV parts suppliers. There are various potable water senders available. Only issue is they usually read in quarters with 4 led's instead of like a fuel gauge that's infinitely incremental.
Darrell
jnack
See Level II in my RV has a strip that is put on the outside of the tank and sent to a monitor that reads in percentage.
It is pretty accurate. Also has other tank monitors, like for black and grey tank as well.
https://www.garnetinstruments.com/products/
that option is very neat! i like that you don't need to drill the tank at all -- downside is the set-up is going to cost me more than the tank, water pump, and electrical to wire everything :unsure:
gp01
