Totally understand the use case, was more curious about positioning. I used to have a mustang racecar with a GT500 vent put into the hood and it dropped temps significantly. It was just behind the radiator and you could watch heat waves pour out of it when stopped after a session.
I'm debating doing something similar to my current 88 Mustang since it tends to run a little too hot for my liking.
Call these guys:
http://trackspecmotorsports.com/
They even have kits for Landcruisers and FJ Cruisers. They are very popular in the road course arena since they do help with lower heat but also improve downforce by releasing underhood pressure. Where you mount them does matter, Ford got it right in the above picture. Mustangs are notorious for capturing too much air in the engine compartment and actually buckling the hood upward at higher speeds...relieving the pressure helps with both lower temps and downforce.
