Arb 37 quart wiring suggestions
john61ct
I doubt that connector pin will not be a resistance bottleneck, maybe even scorching / melting surround if you're actually drawing a continuous 30+A through it.
Go Anderson
toyick
I build Boat Anchors
Go Anderson
Yeah thats why i would go anderson, how ever i doubt he will get that much draw. unless he starts adding to his setup.
am’s and ran 8 awg wire from my Jeep battery (30 amp fuse) to the 7 pin connector. The 7 pin on the
Surprised you managed connecting 8Awg to a RV 7 pin connector.
Even the far beefier SAE J560 connector is 8Awg, and only on its groundpin.
Yeah, it was snug. This is the 7-pin connector I used. Reese Towpower 85475 Professional... https://www.amazon.com/dp/B009F5D81O?ref=yo_pop_ma_swf
If I ever run into any problems, I’ll upgrade to Anderson.
Lockwoodjd
