From Fridge to Camper Van. Thoughts on Removing or Keeping Fridge Liner.
AUM
Hi,
Just committed to a 2014 4x4 Sprinter. The van saw a few years of use as a fridge unit, transporting food stuff, cold, not frozen. Rear box is empty but has a liner, probably not vacuum sealed. From what I see in the windows its stuffed with expansive foam and outer coat seems to be a fiberglass covered resin. It looks pretty clean and well sealed out, no leak holes for water or perforations. Here is a picture so you get an idea. Im buying with the fridge unit removed.
My thoughts are whether I should go through the hassle of removing the liner, or just using this insulation to start out with the build, considering a few cut outs here and there. I will remove the cargo - drive seat panel so i´ll then see what the insides of the liner are. But I also thought cutting down on the floor as well, just to peak under and see if its rusted out. Under the floor rust seems to be the main concern with fridge to camper conversions.
What do ya´ll think?
eporter
I’d do a little inspection to make sure all’s well, and then keep it. Buy a tiny, cheap USB endoscope and feed it through any kind of hole/body plug to check for rust. That insulation job puts you ahead in the game!
Coachgeo
good point... and AFTER- testing for compatibility with material they insulated with; maybe squirt/mist some clorox thru holes as well to de-mildew areas where air got in the holes along with moisture from cycling of temps. When done seal the holes?
Charles R
I'd keep the liner and work with it. If they really did use expanding foam all over the place for insulation, then practically every inch of that liner is 'bonded' in place. Trying to remove all, or even any significant sections, could prove to be a nightmare.
zhukoveli
