Sold: 2018 Ram Promaster Camper Van
newrivermike
Mileage: 12,095
Price: $58,500 or make an offer
Call or text Mike at: (804 357 3805)
The Van:
2018 Ram Promaster 1500
136” wheelbase, high top
3.6L V6 gas engine
6 speed auto transmission
Two key fobs
Front and curtain airbags
Air conditioning
Power locks
Power windows
2 USB charging ports
1 12v socket
Backup camera
Rear park assist proximity sensor
Bluetooth Audio
Aftermarket Cruise Control
interior1rs.jpginterior2rs.jpgoutsidetablers.jpgrearrs.jpgpantryrs.jpgnightlightrs.jpgwindowinteriorrs.jpgfridgers.jpg
The Camper
Insulation: Floor, ceiling, and walls are insulated with a combination of polystyrene foam board, spray foam, and vapor-sealed batt insulation.
Durable vinyl coin flooring with black anodized aluminum trim
Interweave fabric on walls and ceiling
Two double-paned acrylic, awning-style windows—lightweight and insulated
Built in roll down shades and screens on side windows
Two curtains on fixed glass rear windows and two that divide camper from cab
Vented propane locker
Two 11 pound propane tanks with auto changeover regulator
Propex furnace: 6500 BTUs, thermostat, energy and fuel efficient
Stove and sink: Dometic glass top stainless steel combo with electric ignition and faucet powered by electric water pump
Sink drain line terminates at a swivel wing nut that can be attached to gray water tank or piped straight to the ground when boondocking.
Twenty one gallon built in water tank with locking external fill port
Illuminated “analog” water level gauge
Maxxair 10-speed reversible fan with remote and thermostat
Refrigerator: Novakool 1.9 cubic foot DC electric
Inverter: Magnum Dimensions 400 watt pure sine wave
Blue Sea volt meter with 2 USB ports and 12v socket
8 LED overhead lights on single switch
5 concealed red LED night lights on single switch
4 interior LED switch lights: over bed, over bench seat, over galley, in garage
Outside porch lights: one white, one red
Cabinets constructed of Birch veneer plywood with black edge banding and corner trim
Two overhead cabinets on driver’s side, three on passenger side
Pull out pantry with three shelves and drawer
Laminated countertops
Laminated dinette table on Lagun mount
Fold down laminated outside table on back of galley
Gravity fed water hose with valve on back of galley
Cushioned two person bench seat with removable covers
Passenger swivel seat
Five inch layered memory foam mattress, full size, 75” length x 54” width
Recessed walls at head and foot of bed provide an extra four inches of length for a total of 6’5”
Large “garage” storage area beneath bed: 27” height x 42” width x 54” depth with pass through to living area that would allow for 10 foot long objects.
Additional storage over cab, in large garage cubby, and large cubby under bench seat
Marine-quality electrical system utilizing duplex wire and waterproof heat shrink connectors
Isolated battery bank via Powerstream isolator
Two 100 amp hour AGM batteries (total 200 ah)
Two 100 watt solar panels (total 200 watts) with Renogy charge controller
Noco 10 amp shore power battery charger
External 110 volt power inlet
Master power on/off switch
Blue Sea 12 circuit fuse panel with negative bus
Safety kit: Fire extinguisher, smoke detector, carbon monoxide detector, propane gas detector
Owner’s Manual
Pick up/Delivery:
We can figure out the easiest way to get this van into your hands. I’d be happy to pick you up at the airport in Charleston, WV which is about an hour away. We can also discuss the possibility of a delivery.
Call or text Mike at (804 357 3805)
schmack13
Nice looking van. Did you do the conversion yourself?
How are the panels mounted? I would be looking to add an Aluminess rack and move the panels to those.
newrivermike
Hi Schmack, yes I did the conversion myself. There is more info on my website at bridgeboundcampers.com. The van itself has a year of use under its wheels but the camper build is brand new/never used.
The panels are made by Renogy and come with the mounting hardware. Each panel has 4 metal brackets that are screwed into the roof with sheet metal screws. I put some ~4"x4" plywood plates under each bracket in the interior for a little extra something for the screws to bite into. Beneath each bracket I laid down VHB tape for even more strength and water seal. The screws are water sealed with Dicor lap sealant.
The panels were meant to be somewhat permanent, but they'd be very easy to remove if you wanted to. I've got a shop here in Fayetteville, WV and if you were serious about a purchase, I could make the modification and get the Aluminess rack on for you. Another option is to talk to Aluminess about a custom rack that works around the roof fixtures.
Give me a call if you want to talk more.
Thanks,
Mike (804) 357 3805
4xCoffee
