polomasta
Hey all, hoping someone might have some experience that can help me out here.
I have a 2001 E-450 (shuttle bus) with the 7.3l power stroke. I had check engine light on and bought the Kiwi 3 bluetooth dongle and used Forscan app to read the error codes. The codes (Code: P1316 - Injector Driver Module Codes Detected) and subsequent research led me to running a buzz test, the result of which was:
After some additional research, it was apparent that some electrical issue was likely the culprit.
The next thing to try was just a simple checking of connection on the PCM... so I disconnected the batteries, then located and disconnected the PCM. A visual inspection revealed that while it seemed to be in fine shape (all pins looked ok), it did have a lot of dust and dirt all up in the connection area. So I blew it out with air.
I cleared the codes via Forscan, reconnected up the PCM, turned on the rig and what do you know, engine fires up and after a few minutes of idling the codes have note reappeared (like they had previously after just clearing them and restarting engine).
BUT.... now when I open up Forscan, it says "Powertrain Control Module: Unable to read DTC"
I can't seem to find any information if this is good, bad or otherwise... however, I thought/hoped to see "Successful DTC reading, no error codes found" like it says for OBDII & Antilock braking system (see screenshot below).
Other information that might be helpful:
Code:
=== DTC ===
P1272 - Cylinder #2 High To Low Side Fault
Diagnostic Trouble Code details
Injector circuit high to low side open
- cylinder #2
--Possible Causes--
- Open injector circuit.
- Damaged injector.
- Damaged IDM.
- Damaged PCM.
Note: To clear this code, Clear Codes then Retest must be performed.
P1273 - Cylinder #3 High To Low Side Fault
- cylinder #3
--Possible Causes--
- Damaged injector.
- Damaged IDM.
- Damaged PCM.
- vehicle starts w/ PCM attached
- vehicle turns over but does not start with PCM detached
- Forscan is showing error codes for Electronic Crash sensor (see below) but no dash/check-engine lights are on
