Four Wheel Camper - Ranger II for Sale
Willys3b
SOLD Mid nineties ranger II.
I bought this a couple of years ago just to find out if a four wheel camper would work for me. It will, and it is time to upgrade.
This camper will need some work to be functional, and more work to make it nice.
The canvas is in good shape with the exception of the velcro no longer holding. I rebuilt both lift panels but unfortunately this camper has a minor roof leak that I have not repaired. It seems to leak more when closed and over the winter the front lift panel warped. I also damaged the rear lift panel when I left one latch closed the last time I opened it. The front panel is usable but should be replaced. The rear panel needs to be replaced. The icebox is gone. The counter, sink and stove are in place and functional. Original upholstery.
I reworked the front jack attachment points and put four used hydraulic jacks on. I repainted the camper white instead of the red and black it was. I added a base to raise the camper high enough to work in a dodge and this can be removed.
At this point I would rather sell it then fix it.
$700.00
jcbeckwith
I just bought a ranger II and will be installing it on a 2012 Ram 2500. Any suggestions on on getting making an extension on your front jacks mounts? Also, how did you tie it down? Any suggestions? Thanks!
jscusmcvet
You can google four wheel camper tie down and there is a you tube video that shows exactly how they FWC does it when they install. Very simple process.
John
jcbeckwith
Thanks. I looked at a lot of videos, but still can't find something on how to install the turnbuckles from the camper to the truck bed. I found an explanation but I am a visual kind of guy. Hope that makes sense. Thanks.
Clemtiger84
