Removing side barn door hinge pins on GM van?
zuren
Has anyone had rusted hinge pins on their mid-2000s GM van and used this product (no affiliation with Double Arrow):
https://www.ebay.com/itm/automotive...m=R40&rt=nc&_trksid=m570.l1313&LH_TitleDesc=0
I have the 60/40 barn doors on both sides of my van, and I've struggled with the "40" doors since the day I bought it. The pins are severely rusted, to the point that I try to not use those doors and have to constantly tell anyone getting into or out of the van to not open those doors. I had seen this guy's tool for other GM models but the vans had recessed hinges and his solution wouldn't work. Looks like he came up with a new design.
When I called a body shop years ago, they wanted to charge $1000/side to fix my hinges. For $70, it may be worth the risk to try it. I already have the replacement, stainless, greaseable pins to drop in.
Thanks!
Buliwyf
Viking with a Hammer
I just hammered them out after a week of oil.
Tape some rubber to the body and use a punch.
zuren
Tried that. Taped a piece of 1/4" plywood to the van with a cutout for the hinge, after a few days of PB Blaster, and beat with a punch and small sledge hammer. Did not budge.
Choff
I Did it to my door pins, what a ********** !!! what worked is a lot of oil , big hammer and a drive pin to ********** the pins, tape cardboard or rubber to door for protection.
FlipperFla
PB Blaster didnt do the trick? DAMN! Looks like that tool might be the last resort, sure beats $1000
Herbie
Rendezvous Conspirator
If they're anything like the door pins on the rear of Astro/Safari vans, they're splined and expand into the hole as they're driven home. And that make's 'em a ********** to get out.
Here's a photo of a similar pin (same diameter as the Astro OEM, but longer overall, with a slightly shorter splined section):
bGRbf53yycpYTRSuTrYzSWVf_E8KRCSzW1etM9_Cl8ntovbnWLtDrfBDrrRLGxWx-yWUrl87xyX-Izz3YF1VsT8YHBaOnJ7pR0SpacnQax_1X4hvQ9Wzn8g_hqctH_r32ZcMbgo8rka5I3xEVO6p7YjkGAARRdFsRWC-xVKzIdfyyZR-ZfXD3Y3MWhdKbWe7MTh8a0bduEbYgMbX0Ofg4zbaBD261rIBOcn_GwL25EbI-5AWlbFMcmdIUBKDm41mBcZ9KTKvk_tTwTUdUeUqK3en2F1q9oPl6hwsABcEBeKxqeSFoVUDfSita56h5h16hXvktgjAC7AfUyTf_bvoRkVcFrxYQGAeM0CF8GAFaFfPqT7PLUWUIO-RiPVUXnhkBG1A15DjZ62QiyatQ0gjsiRh0cMey6PNU7nDmI0K45POtS4ey2jSaVbDeNsGxtiwpPtvVynkdB49c9immkmRyIPR8sYjJbmlk_II56nL4FbulCzJ39_mAg5jZGsdpbkgdz-WGnNT1brm2nmD4VEWoKpACPaxb1u3B0kmocNPzBmXrggEPLt7atPKPntj8mgoDbdUyh4e6aKUyeV5ycFPUjmIrSPu_tZA8H-FfaVIs_dySv4tWGJkfAsqXM4ut4c_9dsdESiytHbJDklnoD_UdaLTTFUDCcLGXg=w600
When I did the door rack on my driver's side (the first time around), I was able to drive the pins out by using a large socket on the top, and a small socket to push up on the pin, squeezed by a C-clamp (with a cheater-tube on the arm of the c-clamp):
smc0DF9u-4CNK7RBakeWossiu1bUtgf9D5zBCK1dWWMq-xQ08HgvFrDhVELH-Sfkx8mdbWsAzJxXFnhcwJsQSTk-b5LKxPRvSt-_BI8ZW-MnnfHI6nxCngltHJWbBWFMjyCw7z-D3puN2Z93WplE6iExtOJFCBUiaUNUR5js0a7ei3S9D7SjCS14Csfh3zGLe3roGkaFGhbWaV8ptxOiieuYE71JFCkQXd7B6AQ5zei7whDqLz_E__-hiYOrnDo96q6mERg7p8ZZdcTNLCoE81pZUHLcvlWq9P4fqVRcEnqZNAjAR8Aef4IsFTjRyKEXKG5L-kEtAoFtGm3sbAT-P4ddnf2qu9AfCMGZ2w5QYOSvd5P_YP6npBBKIWUFZZxBTbhqwKIhu_XVNQtczGj9oq-VXUJqd4SXPbDDgdSf0Scjxh-hzKVb2ErDyup4Opi1pubgmJypD95SoT8-G1nZTiKydZRSPHEOQleGxz4MhWfq9-pM7YTMp2rC8-ecAFgS-nmAohWVxr7U51Ngz3rO1cTOSkJFph9NvESad33cPIqlubkOa21OGr1NI9VxeK7uGBgna0Mrun2-qZ-K9NwjyziPhWy0rlulgrMZgLitpxuNIyLgkALjm3iUg3XsuJcyeL50RpRO0BEO_RL_eC2wFWHQOtkmbKkXpg=w600
The second time I tried this, I *bent* a couple of C-clamps before the pin came loose, so I used the parts from a different door-pin removal tool to build a tool specifically for the Astro:
KBBGevLKovT2cJGRDWIq3vR9xMP0Q5LADWWppswc90GjwEZSpfa-Eq6WlEBs3VtWPPm7unR4ZS7hR-9mxkj5RbzGFcYZR6p0GtWV8tbPosYSZGd9LA6F3JsYzJY2zEuO3QCaY12IqA7c2y9wAjC8KCINF0Vb4tBwk1f3XPm6Bm8vMnRzu4XyvgB9-B0cAZSxJ3fqowcvFSW1knP_ZjcRBtoWtI7xGHCBjQ9--yfJp3LRwDRSC02knb7uV5gawbrIRoABNPEq159_GfU1AX_QLAvG2zzPWXVQ5uotxmkllXYI7heklbp877Cwz3_1keSWMC17OYD4caiKx24CBdQzSceZFNUGUW8LY73jI5kmlfHpeJ4LOCEDzTvumJMdGGcirVhTladOUkAPNoY5it8pTnv1sHGLgZ-FwfBDbR1yNZatkMbUwVtFJwIGaFUswhzKJ2GUdxTsyBFz6gvWc2reXNbQGtlAwgrfNtEY_KIgA9TfyfAGIaQFnh0WPW2nC9ff7uo_uJhLaDOymPime2Sy5KSPOinDyjYbRIzHU6JlRIhTMZKtAxA3meENVKrhHGOYE8716hJqwGMtfM9DAoh4Doi1IZLuf1SM1V2URw7DXx8oNZkt6m_l1Wtfa41aTbfcTV5Vdg82EAUck1KgRHhtdBp93z4dv4j0LA=w400
Hard to see, due to the lighting, but here are the details:
The bolt on the bottom end is center-drilled to accept a set of hardened steel pins at the end. They're graduated in size, so you start with the short one, and substitute longer ones as you go.
The top plate has a hole large enough to accommodate the head of the door pin. Driving the bolt with the ratchet forces the pin up.
In both cases, the pins let go with a very loud *bang* when I finally got them to release. They're very tight in there!
EDIT: This is the door pin removal tool I cannibalized parts from to build my own tool with. The jaw size isn't wide enough to slip over the Astro hinges (nor the Express, I think).
Choff
Great job Herbie on the removal, looks like the same new pins I put in my GMC Savana AWD-- it's not easy job!!
Main thing when you get the hard work done is to keep them hinges lubed
zuren
My first approach was the C-clamp with the socket trick. I just watched the C-clamp continue to flex with each turn so I backed it off and tried going at it with brute force. The problem with the Express/Savana side doors is the bottom hinge is recessed into the door, so you can't get a clamp in there unless it is specific to the space/job.
I think I'll be ordering some Kroil and that extractor. In the meantime, I'm going to get the process started with some PB Blaster.
These are the pins I have ready to be installed:
https://www.dormanproducts.com/p-74...0Hinge%20Pin%20and%20Bushing%20Kit&origin=YMM
Greasable!!!
bejinscbr
Not sure if you're aware, but they sell complete replacement hinges for the GM side doors at the dealer. I think it was around $70 per hinge the last time I did one. You drill out the spot welds, and then simply bolt them on. Obviously have to paint, but then it's all brand new.
