freewayross
Disclosure: I do not have overheating problems, my deltas are 7 or less. This cooler will be in addition to factory Ford 6.0 cooler. This will be supplement for mountain climbing/ towing and Arizona > 110 F days. Hoping to keep the temps around 180 - 200 always. Most importantly it will give me a new project
Planning on a DIY engine oil cooler, Picked up this cool looking piece of art. It will replace the factory oil filter. To adapt it to factory plumbing I have Amsoil dual bypass filter's adapter, that plugs into the factory hard lines. Have a few questions though if any of the diesel pros can help me out here. Below are my 2 concerns:
All questions, comments and corrections welcome
- Pressure drop- Would there be considerable loss of pressure? The filter unit has -12AN openings, I will be putting in a 50,000 BTU cooler in series which will be controlled by Oil filter housing's thermostat. Planning to keep the hoses short and install the oil cooler under the van with a fan in a safe location. I'm assuming there won't be any considerable pressure loss as BPD also has similar plumbing involved but from a different location. What do you guys think?
- Filteration Requirement & Flow Rate - I believe the factory spec flow rate is 18gpm, need to check the micron rating 8? I guess I can find a spin on filter that satisfies both of those criterias. Any concerns around this that I haven't though about?
