International 4700 Ambo build
java
Still need to get my awning situation figured out! I miss being able to do that with my old truck!!
senorschmidt
I just wanted to say that your build is inspiring. Thanks for sharing it. I've always wanted to have a similar project, but that will have to wait until the kids are older.
Baloo
"The Bear Necessities"
Thanks! I appreciate it! I am sure your will be an amazing project as well.
Added a search light to the Ambo,
Should help out at night.
Also getting a little more counter space,
Baloo
Got most of the motorcycle swing out mount done. I am really happy with how well it works!
Coachgeo
.... 3 images ... Got most of the motorcycle swing out mount done. I am really happy with how well it works! Sent from my iPhone using Tapatalk Pro
I see now you are using tapatalk.... You do know they are hosting your pics right? They are NOT uploaded to here!!!! so be warned..... this awesome thread will eventually be useless junk cause tapatalk will either stop hosting images or hold them ransom like Photobucket has done. So far in the 3 decades I've been at these forums EVERY pic hosting site has eventually shut down and that ruins thousands of great threads like this one all across the net.
On your KLR carrier.... how do you load bike onto carrier? is it setup to have bike either inside or outside when hauling it down the road?
Baloo
Added a back deck and cleaned up my propane locker.
Time for some sanding and paint!
Baloo
Got some things done on the Ambo.
Back windows are gone!
Got the motorcycle mounted
Finally getting some things done, ready for that nice fall weather!
Coachgeo
so the handle bar tucks into a pocket of the door where the window was..... coolio.
what did you use for pocket?
Coachgeo
can you make video of your bike rack ....... very interested in copying it if you do not mind. Really do not want to loose rear door egress.
Baloo
I welded up an aluminum tube, I have welded aluminum three times now, it is not easy!!!
I added enough extra material so I could grind it down to look nice. Then I will glue marine grade carpet to it.
I will take a video of it in action. I am pretty happy with it. I can move the bike inside or out in under a minute!
  • Like
Reactions: B85
Coachgeo
....I will take a video of it in action. I am pretty happy with it. I can move the bike inside or out in under a minute!....
Suspect so or you would not have made the pocket.... but is the rack strong enough to hold bike on the back during transport? Just curious why you want to put the bike inside sometimes?
Baloo
The rack is strong enough to hold my Jeep if I could find a way to get it up there. Yes, it is made for transport, I still have some work to do for the security of the bike to the rack. I don’t like to let the weather beat up the bike, she is a 1987 model, those plastics hate the sun. So when the Ambo is not really getting much use, the bike heads inside till the next adventure.
Baloo
106 miles road trip and the KLR is still outback!
The mount in action!
No contact in tight turns
Ozrockrat
I like how snuggled up to the back the bike is. But am I getting it right. You load the bike by running into inside then putting it onto the rack??
greggarnett
