What did you do to your Expo Jeep today?
CraftsmanCollaborative
Fabbed up a quick bracket to replace the snapped bar pins on the rear shocks of my XJ.
Trying to think of any better methods of mounting the shocks without cutting into the cab, otherwise may remake these a little bit beefier and weld it directly into the factory crossmember system.
theksmith
had that same problem on my XJ that came from Ohio many years ago... both sides snapped the bolts off up inside the unibody when i tried to remove them. i fabbed up a quick solution kinda similar to that JKS product. mine was just a piece of square tube welded between two vertical plates. i bolted each plate to a "frame" rail on each side of the unibody and then put a couple long bolts through the tube for the upper shock mounts, one pointed forward and the other pointed to the back.
jeepdreamer
It's a very common XJ (and others) issue. My '01 had two broken and the other two snapped when trying to remove them. I'm cheap so I fabbed a similar deal for mine. I took it a bit further by removing the body brace and sandwiching the "frame rails". It gave me upper shock mounts and upper brackets for airbags.
Interesting. I’ll have to look into that rail style more while considering the geometry of the shocks. The current setup doesn’t ride bad at all, just thinking long term durability as well.
Lucky j
Not today, but lately.
I had misfire and other code issues with my 2005 LJ. Something that was solved last year, but came back with a vangence. So I went to basic. Check if I had installed the propect spark plugs, with was ok. But decided to look at the gap. Dang, that thing was all over the place on all spark plugs. With an average of 0,60. Adjusted everything as per the hood sticker, reimstalled everything, erase all the code, and after a few drives that totales about 250 miles, nothing has come back.
Time will tell.
My dometic 30qt drawer fridge came in today. Fitted it into the XJ camper build so that it minimizes space gaps and sits flush. Also started cutting and fitting the aluminum tubing around it for the overland platform I I’ll be welding up. Look up @overlandhistory mine will be similar to his in terms of layout in the rear.
American Jeeper
Finished a little video of some moderate trail runs in the JL I am building for overland. There was a big group of AR Overlanders there doing runs. The JL with its extra size won’t be the best on narrow trails, but I think it’s going to be a great platform for overlanding and camping.
off_to
