Hand pump for Adventure Trailers air bags?
jacobconroy
Hillbilly of Leisure
I'm looking for a good and cheap hand pump to deal with the PSI in my Adventure Trailers Chaser air bags. I've used on-board air...but the PSI is so touchy in the trailer that using a compressor is a PITA. One sides leaks a little bit too and I haven't had a chance to "chase" it down...so a hand pump would be easy. I think.
But I haven't tried it yet. Can someone speak up as to how they deal with the Schrader valves on their Chaser? It would be cool if someone could recommend a pump too.
Thanks.
workerdrone
I run from 5-60 lbs in my full size truck airbags and find a standard bicycle floor pump ideal for fine tuning. The bag air capacity is so small it only takes a few strokes to get to wherever I want
nated
Do you think the hose is long enough to reach the valves while you pump on the ground? My valves are on the tongue...not sure about the Horizon.
My plan was to set the pump on the tongue and inflate from there. My Horizon has a nice flat section for the pump.
oskarf150
