And if I'm not mistaken, it was these changes to the suspension in 2014 that caused the drop in payload rating from the normal 3/4 ton range to the dismal ~1500# rating they have now.
''without huge investment''
You already paid that when you bought a PW. PW tax is pretty high around here. Nobody was willing to give me a decent deal on that model. So it was cheaper to build one myself. But I started with a Ford since I prefer the Dana60, and I'm in the salt belt.
OP: Crunch the numbers first. Unless you get a good deal, it might be better to custom build to your exact needs. Especially if a camper is involved. I've got a $14 000 budget to work with before I hit the PW's cost.
$3000 4.88 gears and front locker installed.
$3000 wheels and tires
$3000 4" BDS custom suspension and King 2.5's.
$3000 winch and bumper (which I'll skip because I prefer winching with a Highlift)
manual trans is grossly overrated in trucks
Everyone prefers winching with a hi-lift, unless they have a winch.''without huge investment''
I thought I was to the age that I could accept driving an auto, but now that I own it, it’s the thing I like least about the truck. Glad I still have my first gen with a five speed.
I used to be a 'manual only' kind of guy. But two things changed that perspective:
1) Modern automatics are a whole lot more reliable and more efficient than the older ones.
and
2) I've become dependent on coffee for long road trips; rowing through through the gears doesn't mix well with that habit.
I've driven some of the manual 3/4 ton's (mostly Dodge's); the gear engagement always felt a bit sloppy and vague to me.
^^This^^. I made that mistake once with a jeep. Most of the old adages about manual transmissions over auto are now a farce. Autos now have better fuel economy, are just as reliable or more in some cases, autos now have excellent down hill assist when towing. Manuals still have the edge on vehicles with oversized tires (you can get away without regearing more reasonably as autos tend to 'search for gears' without a proper regear), higher speed offroad driving on gravel or snow is better as you don't have to use the brakes when entering a turn, and in a remote situation it is quite handy to be able to pop start the truck in the event you have a dead battery or bad starter. But the real fact of the matter is once you go from a manual to an auto, you age at a rapid pace (the only way to stay young is to keep driving the manual). Offroading a manual is much more fun (obviously subjective, but accurate). And driver engagement is at an all time high with a manual, no better way to be one with your machine then to know at what speed and what engine noise it is required to shift gears and the overall ‘feel’ of the drivetrain. oh, and since this is what years are best for a power wagon and not a transmission debate, obviously 05-08 as those are the only years that they came in a manual.![]()
If I was going Dodge, I'd want a manual as well. I've never liked their transmissions.
It is still a better option than a Ram auto. Hard off-throttle down shifts and hard/random down shifts with no change in RPM or load aren't normal or acceptable by any other manufacturers standards yet they are in a 2500/3500 Ram. I've done the relearn flash three times now and the transmission characteristics have not improved or changed one bit. It is the one and only problem/concern I have with this truck and I'd say it's a major one and valid after seeing others have their transmissions go out completely while still under warranty and yet have the claim dismissed and have to pay out of pocket.
