I got the front accessory kit, well most of it. It seems ATI is running behind on the damper for the LT4. I'm told mid December until I see the lower pulley/damper.
The news is...everything fits. I'm not sure how it happened, but it appears that everything goes where I hoped it would. I thought that I ordered the 225 amp alternator, but it seems that I did not. I sent the 170 amp alternator back but not before I checked fit.
I had to move the first fuel filter with the pressure gauge slightly inward, which required a new tube that for some reason I already had fabricated. The AC compressor cleared the sump tank, but it has an aluminum cap that goes on the front and the cap was rather close.
The bracket I used to mount the tank had some adjustment left in it that allowed me to move the tank just out of the way.
The idler down on the left has a straight shot up to the compressor, which looked like it might hit the frame. It is obvious in the picture below. A nice thing about the kit is the 8 rib supercharger belt only drives the supercharger.
What the picture above doesn't show is that the supercharger pulley has to be changed to align with the ATI damper.
Here is the power steering pump, which is a PSC upgraded part complete with AN connections.
