ducktapeguy
I have a whynter 45 and it usually has no problem running a day or two on a group 35 battery in Normal conditions.  I have a separate battery pack powering the fridge with watt meters measuring the input and output power draws so I’ve taken measurements on exactly how much energy the fridge uses. The whynter energy usage chart is pretty accurate in my experience.   In typical use the fridge will cycle between 20-70%, but there are a lot of different factors that affect it.
During the cool down period, it’s running at 100% duty cycle, so you can see energy use as much as 1400 wh/day. With pre chilled contents in cool weather it can be as little as 100wh/day. The biggest variable is whether your using it as a fridge or freezer. Trying to freeze items takes a LOT of energy. If you set your fridge at 32 degrees, it’s actually cycling between abut 29-36 s you may be seeing some high energy usage because it’s trying to partially freeze some of the contents. Try setting at 34 degrees and the power draw may drop quite a bit.
