ARB Summit bar does fit the 2010-2013 LR4!
iowalr4
A few people have mentioned they were interested in my project. The new LR4 ARB Summit bar (part no. 3432220) is listed as being for the 2014+ model year LR4. TLDR, it fits!
The area under the headlights is very slightly different and how the headlights and grille fit to each other, but the profile, the curve and where it sits forward is the same. The mounts, and everything else about the panels, fenders, frame, connectors is all compatible. I did not need the metal spacers they provide for under the headlight washers, the 2013 washers stick up more, but fit perfectly with the original clips. On the fog lights, I am using the factory wire loom as is, no modifications. It powers the 55watt ARB fog lights just fine. (the instructions say the OE fogs are 50 watts and you must used an overpriced ARB loom, not true. My OE fogs are listed as 55 w anyway). Parking sensors work fine also. I did have to lightly spray paint the outer two black, because white bumper..
For the winch. You do get some little access doors in the front split pan grille so you can access your clutch lever if you have one. I went with the Zeon Platinum 10-S. The negative cable on the winch just barely reaches the main starter battery ground point, but it does fit. For this winch, you do need the short relocation kit (31") and I think it is a good idea to also do the enhanced signal kit, which replaces the control module brains with one that has a pigtail for the coax antenna cable. I located that little 1" antenna base on my roof, up the A-pillar. (So if the winch is under water it still works with the remote, plus I imagine the bumper is somewhat of a faraday cage and blocks some signal).
One issue I still have is the winch is supposed to allow you to link the high beams to the accessory power ports. I have the 9.5" Intensity lights hooked to the winch via a undocumented blue wire. They work fine with the remote, manually turning them on/off. But when I link them, they wont come on. I have the correct headlight wire tapped, I get 12v from it when brights are on. (I'll call warn about this issue)
Anyway... if you have a 2010+ LR4 and want the summit bar, worry not. It is a billion steps to complete, but I took my time and it wasn't difficult at all.
Full parts list.
• ARB Summit Front Bull Bar (part no. 3432220)
• ARB Winch install kit (part no. 3500720)
• ARB Fog light kit and covers (part no. 3500590, 3500680)
• ARB Hawse Fairlead Spacer Kit (part no. 3500600)
• Warn Zeon Platinum 10-s (part no. W92815)
• Warn Enhanced Signal Kit (Part no. W94288)
• Warn Short Relocation Kit, 31" (Part no. W89970)
• ARB Intensity 9.5" Spot, and Flood lights (Part no. AR32S, AR32F)
Control pack fits nicely here. I have the intensity lights plugged into the control pack. they use 2-pin trailer connectors.
Split pan grille.
Access doors on left and right for access to clutch levers. The winch mounts feet forward, so you would need to clock your case 90 degrees to make the lever point up.
You can adjust the bar fitment to be close to the headlights (up or in). I left a finger gap just for impact to protect the lights. I also didn't quite get my fender cuts perfect, so I wanted to leave it there.
Goes nicely with the Tactical 4x4 bumper. (I have my tire and dual jerry swing off, this is non-trip mode for the rig, when I want the camera and parking sensors)
I am pretty sure I saw this bumper on a RR sport, so that is part of what made me just try this. I knew it couldn't be that much different.
-Mike
iowalr4
I heard back from Warn regarding the high beam connection wire on the platinum winch.
The blue wire is the correct wire, however it doesn't provide the function I was hoping.
Apparently, in EU or somewhere you can only use aux lights when you also have the high beams on. Thats fine. But the blue wire doesn't sense 12v and then turn the lights on for you, it just only lets you (manually with the remote) turn the lights on if you have your high beams on.
So I will have to just add a relay and wire that up to the lights on another circuit so I can turn them on with the high beams. Kinda sucks because I was hoping to be able to configure which of the two lights came on with the brights and just change that as desired, Ill have to install switches or two relays to achieve that.
mk216v
Der Chef der Fahrzeuge
Thanks for posting pics, looks great!
How do you like driving with the driver side ARB spot and pass side ARB flood? Have any pics at night to post?
Carson G
I thought the grills, lights and fenders were interchangeable from LR3 to LR4? What makes these components different and required to be changed on the LR3 to fit the summit bar?
They will fit on the LR3 but they’re not the same. The lights and grille are shaped a bit different the fenders are also trimmed to accommodate the different shaped headlights. The summit bar may fit with the LR3 front end but I’m not 100% sure about the fitment around the lights and grille.
mk216v
PS--I have these now on my '06 RRS w/ LR4 ARB Sahara front bumper. The big lamps work well. They're a bit too high a Kelvin rating (guessing maybe 6000k'ish?) for me (I prefer the ~5000k of my Rigid 50" bar on another rig), but I still like them.
