E350 post Grocery getter re-gear or not
Paddy
3.55 is very tall gears. I’d definitely consider 4.10’s and a trutrac, regardless of engine mods.
Raul
I have 305/68r18 tires and went from 3.73 to 4.10 gears. I am quite pleased. The ratio from stock tires/gear to the new ones remained unchanged. I am quite pleased with it. If you go to 4.10 your combined ratio will be shorter than mine, which may
a good thing if you do towing or mountain driving.
Check this calculator to compare your previous tire and gear with the new tires.
https://tiresize.com/gear-ratio-calculator/
Yep, what I’m seeing is 3.93 would be for best MPG’s but 4.10 would be “best overall”
PNWav
