Questions regarding ARB RTT
outdoornate65
Hoping someone can help me out with some info about the ARB RTT.
I'm looking at a used tent to mount on my trailer but need to make sure it will fit the crossbars I have......48" span.
Can anyone tell me how long the mounting track on the bottom of the tent is?
Also, is it possible to move/turn the mounting tracks 90 degrees on the tent....allowing for a different opening orientation?
Thanks in advance,
Nate
crazysccrmd
If the two tracks on the bottom of the tent are mounted on the long axis you can turn them to the short axis and trim off the extra length. If they’re already on the short axis you’re out of luck without buying new ones. Depending on tent orientation 48” is not a problem.
outdoornate65
Thanks...
I found a PDF file with the mounting instructions for the ARB Simpson RTT. I'm assuming it's the same set-up for the "Touring" model.
gp01
