Looking for a Jaos Rear Ladder for Montero Gen. 3
Hj61socal
I know this is a long shot but also know there are plenty of Jaos ladders out there floating around on vehicles. I have a nice build I've done on a 2001 Montero Limited and am in need of a Jaos rear ladder for it. Please let me know if you have one or come across one. Would be greatly appreciative.
christo4ra
Looks great!! Hey what’s the wheel and tire size you’re running? I just got a gen 3 and would like to get a wider look/feel. Did you buy negative offset wheels, or use spacers? Thanks!
Hj61socal
I put 265/75/16 on there with centering rings I believe 110 by 67.1mm. The tires do rub however in reverse if cranked all the way. I'd go one size smaller because lifting it will not fix the wheel well clearance issue
Linesman1776
