RAM 1500 - Mobile VHF/UHF Radio install
kiloxraysierra
I am a fairly new amateur radio operator, licensed in June of 2018. I played around mostly on HF for the few few months until I acquired a handheld Yaesu VX-7R before Christmas. Around the same time I stumbled across the Overland Bound Weekly Net and realized nets would be a great way to get some use out of the radio and build some communications skills. I started looking around for repeaters and clubs in my area that host regular nets and found a few, one at the same time as my drive to work. The HT didn't work so well in the truck with the stock antenna, so I picked up a Diamond mag-mount 2m/70cm antenna (https://radioworld.ca/dia-mr77sma) which improved things significantly.
Distracted driving laws in Ontario do have an exemption for licensed amateur radio operators, but the device has to be securely attached to the vehicle. I connected a belt clip for the VX-7R to some RAM mounts in the console and used a speaker microphone to comply. I was getting ok signal reports, but the HT picked up quite a bit of QRM and I wasn't always able to reliably get into the repeater hosting the morning net with just 5W. Time to upgrade!
The radio:
The VX-7R has true dual-VFO which I found fairly handy for monitoring one frequency while scanning others, so I wanted the same for a new radio. I was also interested in APRS and having a unit with a remote head. Radioworld in Ontario had the Yaesu FTM-400XDR on sale since before Christmas, and essentially sold-out and on back order the whole time. I checked back regularly and one Friday afternoon saw they had some stock. A quick call put a hold on the only unit they had in inventory and I drove over to Toronto to pick it up on the Saturday. I purchased a remote speaker at the same time (Yaesu MLS-200-M10).
The install:
I drive a 2017 RAM 1500 and had to spend quite a bit of time reading forums and watching YouTube videos to get ideas for a clean install. I found some good info here on Expedition Portal and wanted to post something to give back.
I wanted the body hidden away and protected and I wanted the head unit right at hand so I wasn't reaching a long way to operate the controls. I decided to put the body beneath & behind this console and the head unit on the RAM mount.
507745
First go around, I put the remote speaker in the console as well. There are a few gaps in the upper console so it seemed like a good idea. I had setup the radio on my desk with the speaker plugged in and it seemed ridiculously loud. You can see it to the left of the base unit in the picture below.
I was in a bit of a hurry so I just ran the mic and head unit cables out the knock-out on the left side of the picture below. The body is just zip-tied to an existing bracket, however you do have to unclip a few factory clips and push them down and out of the way. There isn't a lot of clearance in the rear of the radio so I have a 90' adapter on the UHF input. Power was run using 10 gauge wire over into the driver's foot well and through a plate covering the unused clutch pedal hole. I used a Daystar KU20040BK Black Universal Firewall (available from Amazon) and protected the wires with plastic wire loom. Both the positive and negative wires have 15A fuses, with the positive direct to the battery and the negative to the chassis ground beside the fuse box.
508612
That was version 1.0. I wasn't happy with the cable routing and the speaker wasn't loud enough - I had to run at 75% volume when driving down the highway, so I did it over.
This time I found these RJ-12 inline adapters: https://canada.newark.com/l-com/ecf5046s-bk/rj12-coupler-jack-jack-6pos-cat3/dp/50AC8548 to use as passthru connectors to the console. FYI - the mic cable is a 6-wire RJ-12 connection (straight through). The head unit has a 4-wire RJ-9 connection (also straight through), and since I couldn't find any of the inline adapters for an RJ-9, I had to build some cables. Turns out the curly cable for an old-school telephone handset is a 4-wire RJ-9 cable (but cross-over). Cut it in half and attach RJ-12 connectors using just the middle 4 slots on the RJ-12 (and making sure you wire it as straight through). Now you are able to use it with the RJ-12 inline adapters. You can see the cables I built below (the curly ones on the right). The straight cable on the left is a commercial 6-wire RJ-12 straight cable, but ended up being too short so I made another using CAT5 cable.
507747
Next onto mounting the passthru adapters. My original thought was to put both at the front edge under the cardholder ledge. I wasn't 100% sure they'd fit given their size and the curve of the bin so I decided to put just the head unit jack there. Due to clearance issues, the only other spot for the mic adapter was in the rear of the bin.
Backside view of the connection for head unit at the front of the bin (black curly wire):
507748
Backside view of the connection for the mic at the back of the bin (white wire):
507749
Finished product:
507750
I'm not totally happy with the mic connection at the rear of the bin - it feels like it takes up a lot of the bin space. I may take another stab at putting it at the front and fill the hole in the rear with USB ports or something. I've ordered a few more bits and bobbles for the RAM mount to add another arm and a mic holder. I'll post more pics when those parts are installed.
The speaker I moved to under the driver's seat. There is a little plate holding an electrical connection that is strangely much bigger than it needs to be and also has a hole pattern that fits a few of the holes in the speaker stand. Excuse the dirt, it was getting late fast and I just wanted this done.
507751
I've been running this for a week or so, and I'm not sure it's an improvement over the in-console location. It's adequate for sure, but I'm still running at 75% volume on the highway. I've decided to buy a Bayou Goat mount (http://www.bayougoatmounts.com/single-disk-for-the--2013-2018-ram-truck.html) and mount the speaker right above the stereo display screen on the dash. That should improve the sound! I'll also post pics when I've moved it again.
[edit: replaced the picture showing the base unit]
PhulesAU
I see what you mean, but maybe room for small speaker?? on the end so it would be a bit like wearing an ear piece?
kiloxraysierra
I’ll keep that in mind as option 4. Option 3 will have it on the dash just above the screen for the stereo head unit. Not exactly stealth, but I don’t mind the look of the round speaker housing.
Someone over on ramforumz.com actually had a shop put a speaker in the headliner just behind the console on the angled bit. Pretty stealth, but maybe a bit beyond my comfort level.
I'm considering a mount in my '18 2500. My local stereo shop recommended using the center channel speaker on the dash as a communication speaker. They said that this speaker really does not help the sound from the stereo.
The process would be to snip the speaker wires across this speaker, and put a high wattage 8ohm resistor on that circuit as to not blow up the amp in the stereo.
The speaker can then be wired to the speaker out on the radio.
I have not yet done it, so I can't yet comment on how well it worked.
kiloxraysierra
Managed to move the speaker up to the dash location last night. Required volume dropped from 75% to 40%, so decent improvement. The Bayou Goat mount has a bit of give to it, and the speaker is not exactly lightweight so it bobbles a bit. We'll see how it holds up. Happy with the performance for now though!
508761
kiloxraysierra
Added some RAM mount bits to hold the mic. It is now in a decent position to grab without looking while driving. The lock mechanism takes some practice though.
509702
509703
Parts list for those interested (for just the secondary arm and mic holder):
RAM-B-273U - RAM BASE W/1/4"-20 HOLE HEX & 1" BALL
RAM-VC-MC - RAM SINGLE MIC CLIP FOR FACEPLATES
RAM-B-202U - UNPKD. RAM 2 7/16" DIA.BASE WITH 1" BALL
RAM-B-201U - UNPKD RAM DOUBLE SOCKET ARM FOR 1" BALL
kiloxraysierra
I have been planning to install an NMO mounted antenna on my truck since the beginning. I installed a mag-mount antenna when first started operating with my handheld and it worked reasonably well. I noticed recently the coax cable started to scratch the paint, so there was a bit of urgency to install the NMO mount.
I decided to order the Larsen NMO-2/70K kit from GPS Central after seeing it mentioned several times across many different forums. I realize it is ridiculously tall, especially on a truck that sits about 6'2" on it's own, but I don't think it will be a problem. I avoid parking garages already and life won't be that much worse if I have to walk into a restaurant instead of going through the drive-thru. I did order the heavy-duty rain cap, which I'll leave in the truck if I absolutely have to take the antenna off.
I have seen two methods of creating the hole for the NMO - drilling and a hole punch. Originally I thought the hole punch would be the better method - it appears to create a much cleaner hole. However, the more I thought about it the more difficult it seemed. A 3/4" hole punch still needs a 1/2" hole for the draw bolt. Plus you need access to both sides to get it started. After watching a few videos on dropping the headliner in a RAM 1500, I decided it would be way too hard to use a hole punch and went ahead and ordered a Larsen HS1 3/4" hole saw for NMO antenna mounting. It arrived earlier this week, so I was ready to get started.
I disconnected the battery and dropped the headliner on the passenger side to get an idea of the roof structure. There is a beam running between the B pillars - it's nearly a foot wide. Basically the entire distance between the green tape marks below. I will be installing a GFC camper that overhangs the cab a bit past the rear edge of the back door glass, so I figured installing in front of the beam would be safer.
510066
Didn't want it too far forward and by eyeballing marked a spot I thought was just in front of the beam. Turns out I was a touch too close:
510067
510069
Luckily, by mounting the NMO with the cable pointing to the passenger side, there was still plenty of room to tighten it down. Lucky! I used a bit of dielectric grease on the gasket under the NMO mount so it wouldn't bind as I tightened it down with the channel lock pliers. I did the same to the top channel of the Larsen Super Seal Gasket so the antenna base would slide as it tightened. I'm hoping two seals do the trick.
510070
510071
A wire harness near the windshield had these handy spare U-clips already attached, so I used those to route the coax down the passenger side A pillar (making sure to stay well clear of the airbag) and then under the glove box to the center console.
510072
Overall, I think I am happy with the current state of affairs. The antenna looks great and works great too. It seemed like reception is better than with the 1/4 wave mag mount I was using previously.
510073
kiloxraysierra
Since I was pulling everything apart, I decide to move the loud speaker as well. The Bayou Goat mount I purchased was clearly not built for the weight of the Yaesu MLS-200-M10. If I had ordered the "triple mount", I may have been OK as it appears to lay flat on top of the console, while the "single mount" I ordered is entirely supported by one leg on a flexible cross member. It bounced around quite a bit and was fairly distracting.
There is quite a bit of room behind the center console under the screen. In addition, there is a little storage near the bottom with a "ceiling" that slopes back into the console. The "ceiling" is not visible from the front seats, so I decided to drill it full of holes and mount the speaker to drive down towards it. In the picture below, the storage area is holding my sunglasses. There is quite a bit more depth to it. In the second picture you can see it from the back, full of holes.
510074
510075
There was a handy cross-member below the radio screen that I used to mount the speaker. The bottom half is just plastic, but the top two holes I had to drill through a metal support (which is great - the speaker is heavy and I was worried about the plastic holding it).
510076
510077
I was a little nervous putting it all back together, but everything went together perfectly. I do need to drive it at a higher volume level, but it's not as bad as when it was installed under the seat.
iStan814
