Copperhead14
Any update on warranty?
			You got a point, I never thought of that.Won’t trussing the axle without addressing the radius arms just transfer the stress to the radius arm frame brackets? Soon you’ll be ripping those off.
Maybe I’m not comprehending the physics right, but it seems like a Johnny joint at the frame side (like Carli does it with their spherical bearing) would allow rotational movement there that the bushings don’t. Or are we talking a spherical bearing at one of the radius arm axle mounts in addition to the one at the frame side? Perhaps that would send those lateral stresses onto the track bar alone, but I’d wager it’s easier to reinforce that than deal with the other issues.
That’s too bad, sorry you encountered it.
Going with a completely new axle if they deny warranty? Or gonna have yours re-tubes and trussed? Seems like it’s still salvageable.
Wouldn’t swapping the front over to a 4 link solve most these issues?
	the problem comes from the fact that the front axle is suspeneded by radius arms. radius arms are great for ease of manufacturing and street vehicles that dont work outside of the confines of the stock rubber bushings. Thats why Power Wagons got the Articu-link front radius arms, that are double jointed for the upper link. As the axle drops down on one side, the upper and lower mounts are moving in different planes. The Articu-link adds another rubber bushing in there, and disconnects the upper link from the solid stamping of the entire radius arm. A significant portion of the twisting motion of the radius arm is done by the boxed steel section itself, and the remaining load by the rubber bushings.
the only way to get past this is to divide the upper and lower links from each other, whether thats a 4-link with panhard or what, thats what needs to happen - all four mounting points on the axle need to be able to move in their own planes. So far, the only MFG that i know of that accomplishes this outside of the OEM Articu-link's on the PW, is Lewis Built's HD radius arms that use a Johnny Joint and a FK rod end. downside of moving to spherical bearings and rod ends is that they will need to be replaced as the races wear out, and in a truck this heavy, i would say you will be looking at 50,000 mile Johnny Joint rebuilds.
Would the fact that it has 42" tires compound the stresses on the axle or is this issue directly caused by the suspension movement? As in my stock 14 Ram 2500 could see the same problem if subjected to a lot of articulation? I know I'm dumb but I cant wrap my head around what's happened. If I'm imagining it correctly, say your looking straight down from the top of the truck. The left side of your axle has been bent towards the drivers side door basically?
