Exhaust recommendations?
NorthCounty
Time to replace my exhaust in the '94 SR 3.5l dohc. Looking for any advice or recommendations from anyone who has swapped out OEM exhaust components. Looking at replacing cat, muffler and tail pipe. Current stuff is original OEM (200k) and has seen better days. My like would to replace with aftermarket bolt-in pieces. I am not a fan of the universal stuff that gets welded in place. My plan is to get bolt-in cat / muffler / tail pipe and then take those items to an exhaust shop for tweaking / install. Expect maybe some welding or bending. Anyone have any recommendations?
My '94 is a non-Cal / Fed 3.5l. Single O2 just prior to cat and non-OBD2.
jeep-N-montero
Appreciate the insight. My little bit of research suggests there are "bolt on" options available per retailers. Clearly a foolish question to ask.
Most retailers are idiots when it comes to Monteros, what bolt-on options are you referring to specifically?
Salonika
Monterror Pilot
On this topic, I’m in the rust belt with a 98 and all I’ve ever needed to do was weld on some new hangers a few times and a new inlet pipe to the muffler. My whole system is still alive and well.
Tho
