AT Overland- 2018 Promaster Build ( Mountain Bike Adventure Van)
Cummins_expo
We have been getting requests regularly to build out adventure based vans, we have done several but not really documented them before. A local couple had contacted us to build them a Promaster Adventure Van. Their primary focus was to transport mountain bikes and have a place to stay in between rides. They typically go out for 4-5 days at a time.
Build- 2018 Promaster
Focus- Moutain Bike Hauler/ Camper
List of adds:
Solar
Fresh drinking water
Outside Hot Shower
Space to fit 3 LARGE mountain bikes inside
12v Fridge
Max Air Fan
Porta potty
Cabinets for gear and clothing
Smally galley to prep food
Outside hook up for outdoor cooking
Led Lighting
Power ports to charge
Cummins_expo
Now the part people actually want to see pictures !!!
The first step get the Promaster drawn in 3D
Fat mat the interior
Using the 3d models really expedites the panel making process
Fire up the Shopbot
All the floor insulation cut on the shopbot same as the subfloor
Sub floor will get sealed and treated
b. rock
Is that bench going to move or be static? I have a similar design in mind for an E350 but was thinking of making the bench an option for extra campers, if need be.
Cummins_expo
The original design allowed the bench to serve as a bottom bunk. This customer decide they wanted a fixed bench and bed- I will see if I can pull up images of the design
Cummins_expo
This was the idea ( with smaller galley cabinet) if you wanted the ability to sleep multiple- The lower bed platform uses the wheel wells as support
Cummins_expo
That looks better than expected. Does covering wood with bed liner really waterproof it?
It first gets a coat of poly- The bed liner material is the same stuff we coat our under bed boxes with. This will also give it an "outdoor activity" safe surface toss muddy gear, bikes, you name it.
Cummins_expo
Once you spend a little time designing you can create easy "Ikea" assembly drawers.
Pre-drilled holes for your soft close drawer slides
self-aligning joints and groves for bottoms
