Toyota 4Runner - turn key rig
AdventureMotors
Hey folks! I've got a turn key 4Runner for sale! Detail below;
2013 Toyota 4Runner currently sitting right around 111k mile.
This is a factory shoreline blue pearl NON KDSS rig.
The exterior has been converted to a 2014+ front end. Have pictures of entire process (conversion was not due to wreck). All OEM parts were used and one of the premier paint shops in KC did the conversion. A custom paint / texture was applied on all the fender flares to retain the iconic 10-13 black flare look without going with hideous bushwackers.
The interior was semi converted to 2014+. The lower dash, door skins, glovebox, center console, seats, etc. are from a 2016 Trail Premium that had 16k miles. The carpet is a new OEM carpet kit from Toyota.
Suspension;
Dobinsons MRR front coilovers
Dobinsons MRR rear shocks
Toytec Superflex HD rear coils
Total Choas complete rear long travel link kit
SPC Adjustable front upper control arms
Timbren Industries front and rear active bump stops
Dobinsons extended rear sway bar end links
Engine and Drivetrain;
WAT Nomad valve body upgrade
ECGS complete 4.56 re-gear
URD Y-pipe
URD Maf tuner
Custom cat-back side exit exhaust
ARB Diff breathers
ARB Snorkel
FN Overland 17x8 wheels with 285/70-17 Nitto Ridge Grapplers (set of five tires total, four wheels). Whole set has roughly 8k miles on it.
Armor;
Complete RCI Off Road 1/4” aluminum skid plate set
RCI Off Road sliders
RCI Off Road rear diff skid
Exterior;
C4 Fabrication Lo-Pro with Smittybilt X20 10k synthetic line winch and Extreme LED light bar
Baja Designs foglight replacement kit
Baja Designs rear lights custom mounted in bumper
Extreme LED rack mounted rear light bar
Rigid Industries side lights (driver and passenger)
CBI Ditch light brackets with Extreme LED amber lights
Frontrunner Outfitters roof rack
Gobi rear ladder
Electronics;
C4 fabrication dual battery tray
Two group 34R extreme duty AGM batteries
Upgraded main harness and wiring
Blue Sea ML-ACR dual battery controller
Blue Sea 6 position distribution block
Switch Pro 9100s controller
Snomaster traveler 12 custom mounted in center console
Expedition essentials tray mount with ram smart phone mount
Victron solar charge controller
Top of the line Yaesu GMRS / Ham radio
Misc;
Orange Box fabrication PSD racks on driver and passenger side
Weathertech floor mats
Removed rear cargo slide and installed solid platform base. OEM cargo tray and ALL components are included in the sale.
TRD Pro shift knob
All interior lights converted to LED
Replaced OEM parts in last 8k miles;
Lower control arms, bushings, and adjusters
CV axles
Tie rod end links
Sway bar end links
Alternator
Starter
Spark plugs
Water pump
Idler
Tension
Drive belt
Brake fluid
Power steering fluid
Transmission fluid, diff fluid, transfercase fluid
Rig will also come with various roof rack accessories (wolk pack, maxtrax mounts, maxtrax's, etc.)
Rig is offered at $50k. Clean and clear title in hand with no liens. Shipping can be provided at a heavily discounted rate.
MTSN
So it could be unique. This color is my favorite paint that Toyota has produced and thought it would look amazing with the 14+ front end.
I was asking about the interior when I quoted you. New carpet and new various pieces on the interior seems like flood damage or something, so you might want to shed some light on that. That combined with a lot of body work, paint color change, etc. is something that will likely cause a lot of questions.
AdventureMotors
Ahhh, gotcha.
No, no flood damage or anything of the sorts. I have pictures documenting it all.
I'm just a clean freak and get oem parts at a discount so I wanted everything done right when I updated the interior. The various pieces of the interior were done to update it and get the grey out of the interior when the seating was done so everything looked all uniform.
There was no paint color change. It's the factory shoreline blue pearl with the 14+ front end conversion.
Thanks!
northstar2018
Northstar
I often keep track of your Adventure Motors website listings, but do not see this stunning beast on your web page. Just curious, listing here first?
