Fuso FG649 Frame rebuild help
stormsails
I'm starting to research replacing frame rails on my FG649. I will just be replacing the rear of the frame at the joint about a 9ft section. Anyone have any experience on best steel to use. Can I get away with using 1/4 mild steel and just forming the rails with a press break, from what I can tell the original frame is around 3/16 but not mild steel. I'm in Northern Canada so shipping from the US isn't worth it.
gait
Pugsly hasn't posted for a while, there's a thread on this forum where he rebuilt a whole frame and probably has a good drawing and some advice on steel.
pugslyyy
You have to use a high strength alloy, mild steel will not do the job. I laid mine out in Autodesk inventor and had a local heavy fabricator build the frame rails and crossmembers.
The stock frame is .177 44k psi yield HSLA steel
My replacement frame is .25 80k psi yield HSLA steel.
512928
stormsails
I just looked at your build. Do you have any problems with your frame being to stiff. I know the original frame was built to be pretty flexible. Do you think maybe A656 3/16 or would you stick with 1/4. I'm just planning on using it for a truck camper.
PNWav
