vintageracer
To Infinity and Beyond!
Good answer honey!
Air Lift is a great product. I've had them before and am considering AirLift or Firestone on my TJ. Nothing wrong with using a hand pump to level the load.One thing that we are considering is adding the helper air springs in the back. I would just plumb a simple schrader valve and manually inflate/deflate for simplicity. What are people's thoughts on these?
https://project-jk.com/jeep-jk-write-ups/air-lift-1000-air-springs-installation-write-up
Given the GVWR is legally fixed by the DOT, I don't think it's possible to load up an Unlimited JK with typical 'safari' style parts the way you would a Defender or a Land Cruiser without being over that weight rating. The only solution for most of the areas of heavy weight is to spend more money on lighter components, or sacrifice some components (and the utility they provide). I feel anyone choosing the Jeep for an Overlanding application really needs to think long and hard about how limited the JK is in terms of payload, and how those limitations translate into utility of the vehicle. It can be the greatest off roader in the world (and I think it is), but if I'm limited to weekend trips because of the GVWR, it's functionally useless for me as compared to other rigs.
Incredibly well said. My JKU is the living (and massively expensive) example of this lesson. How did I end up here? 1) I love offroading. 2) I love overlanding. 3) AEV has a really impressive website.
My AEV steel bumpers, Metalcloak skid plates and DOM steel side rails have withstood massive strikes and impact on severe trail terrain. My Tepui tent, side mounted water tanks, Dometic fridge and Genesis dual battery system have made long trips into the wilderness a source of addictive joy. And my GVW is an absolute disaster.
And, we eventually want to have kids which will add a good chunk of weight.
Why not get a trailer if you are carring allot of weight?
That’s a very good suggestion and would work for most folks. Trailers can be a great option for a lot of different travel styles, but they can also be limiting. Tight switchbacks get harder as does international shipping of the rig. It also introduces another good chunk of failure points that can reduce reliability overall. 50% greater chance of punctures, extra wear and tear on drivetrain, more ball joints and suspension components that can go pear shaped; ideally they are common between the rig and the trailer but that’s not always the case. Even with a trailer the process of lightening a load or at least looking critically at weights can be beneficial, though.
A trailer and a JK is good for most situations, though, and is the only option really if you are going with 4 adults in one rig. With smaller parties a trailer nearly eliminates the weight issue unless a person likes to bring A TON of stuff. Still for us the cons outweigh the benefits.
I'm not an expert, but just my opinion. In worst case scenario.
1. The increased risk to anything related to starting, stopping, and moving. Bad gas mileage and brakes are probably the most minor. Added weight puts more stress on the engine, drivetrain, suspension, brakes, and almost any other moving part of the vehicle that probably weren't designed for it. Engine components will wear quicker, stopping distances increase, handling suffers. Springs will weaken faster, Bushings will wear down sooner, axles might twist, transmission may overheat or clutches burn out, shocks mounts might break, etc. Anything that moves were designed for a certain load + some overhead for a safety factor. Increase that load too much and you run the risk of breaking.
2. You can upgrade certain parts to be stronger, which ironically will just make your rig heavier. But all you're doing is pushing the weak link down the line somewhere. The added stress still goes somewhere. Bigger engine can deliver more power, but now your axles need to be upgraded to handle it. Stronger axles can fix that, but now the driveshaft is the weak point. Fix the driveshaft and now it's the transmission, and so on. Eventually after upgrading everything, it might be the frame .........
Most of those failure points are hypothetical. If your JKU is overloaded you are doing more damage than towing a trailer will do. 50% more tires, yes but none of them are overloaded. The JKU is RATED to tow 3500#, you won't even notice 2000# but you will not be overloaded either. There is no "extra" wear and tear if you stay within the design limits. And I've never in 40 years damaged a trailer suspension.It introduces another good chunk of failure points that can reduce reliability overall. 50% greater chance of punctures, extra wear and tear on drivetrain, more ball joints and suspension components that can go pear shaped.
To an extent I will agree but many of the reliability / mechanical issues you speak of will be greatly increased when you over load your vehicle, maybe more so than towing within the weight limits the vehicle is designed to tow. I would be more concerned about tire failure with an over loaded vehicle than the extra tires on a the trailer.
So you feel safer doing technical terrain with an overweight rig?In very technical terrain, though, a trailer is going to get bashed and bounced around, and that does translate into more wear and tear on the rig — with occasional use though that shouldn’t matter. And I would suggest this is mostly a concern in areas/terrain where there is a high risk of damage to an untrailered rig
