SOLD: Blue Sea ML-ACR 7622 with custom wiring - ready to go dual battery setup!
jeegro
$180 shipped USPS priority mail to USA.
Everything works great, I'm moving to a lithium battery.
Includes ML-ACR, switch, wiring, 3 custom 2/0 gauge cables, and an aluminum mount for the ACR.
Mount: it leaves a gap so you can slide it into a battery retainer bar.
Switch wiring is about 10 feet, perfect for a dash install. It uses a plug at the ACR end so you can easily remove the batteries (it was designed to be mounted on top of the batteries).
All the custom work I did is easily undoable if you choose to hook it up a different way
dhuss
