AEV 40” Kit
Adventurous
Thuren full suspension and 40's.
MORE PICS!!!
What's the back spacing on those wheels?
blackdmax15
Yo reloader I just sent a request via Instagram. I’m about to pull the trigger and start phase two of my build and looking to mirror your fenders etc. Any more specs etc would be appreciated. Also how long did it take to have the TR beads made?
Ravenmad
I ordered walker evens deadlocks in 17x8.5 -19 (4" backspace) prior to KOH, beautiful wheel and they weren't to bad at around $400 a wheel. I do have a little rubbing, but thats because of the 43" tires lol.... I think the 4" backspace wheel is a good compromise considering scrub radius and clearance.
Bayou Boy
WOW...what's the overall height of your truck. That thing is massive.
Ravenmad
Its not to bad, deff. on the outer limits of the word "proportionate" though.... 43s rub under full compression with the front sway bar removed though, with the sway bar connected they clear with only a slight rub at full lock on the radius arm and a very slight rub on the inner fender liner at the lower cab cap piece.
That looks great. I'm on the limits of clearance fully stuffed lock to lock. If I push the axle forward 1/2" I can probably fit 42's. If I had to do it all over again I'd probably go 20x9 with 20mm(ish) of offset. Looking down the side of the truck my tires are right at the edge of the flares, 15.5" wide tires would stick out a little. I'd like a set of Treps, maybe next time.
Ddenney
I'd love to see if anyone has ran the fenders on one of the pre 14 trucks. I have a 2011 power wagon that I'd love to turn into that!
project13support
