jacobconroy
Hillbilly of Leisure
Got my "attic" net today. After a little shopping, the TruShield Rear Overhead Net seemed to be priced reasonably. It appears to be pretty heavy duty. Thick webbing, buckles, and solid stitching. I really yanked on the buckles to tighten things up and had no issues.
First off, the buckles for this are meant to go on top of the speaker bar. I'm not taking the top off for that. And, I want more space to stuff soft gear in there...so I mounted it upside down. This is a loose fit to see what's what.
I tightened the crap out of it, tied off the extra webbing, and stuffed some goodies in there. Down quilt, insulated jacket, hardshell jacket and hardshell pants, and puppy jackets:
Then "oops". The rear part of the net that drops down interferes with the National Luna lid.
I moved the rear part up and tied it down. Now everything works.
This is why I don't like fridge slides. Unlock the slide, pull out the fridge, undo the latches, open the lid, pull out a tray, return the tray, close the lid, close the latches, push in the fridge, lock the slide. Then CRAP!!!! I forgot to grab the mustard! Start over again. TOO MUCH SCREWING AROUND!!!!. Now I open, grab, and close. Highly recommended.
I had worried about not getting webbing that has mesh sewn in. Now I'm glad I didn't. The holes in the webbing will make the soft gear stick there by trapping it in. Overall, I like it. Really, really easy to grab things and stuff things back in. After I use it for a trip or two, I'll either figure out a way to mount the rear section higher to get more storage space...or cut it off with the hot knife.
