I'm trying to keep the airflow from dropping down to hit the front of the cargo carrier. I guess I could telescope the tongue, and check my mileage at different lengths. My Prius gives cumulative MPG readings. The trunk lip is 44 inches from the ground, and the front of the carrier is 39 inches from the ground. The carrier is 67 inches long, and I plan to stretch the trailer box by 19 inches.You may not have noticed, but the carrier is mounted backwards from the way it would be on the top of a car, to give it a rearward taper. I appreciate your learned advice.
