Congrats! Yes I think I will go with the 265s after all. As far a fuel economy goes I am getting 19.7 mpg with an atv and gear in the bed under mix driving conditions so 15mpg seems reasonable fully loaded with 265 KM3s in most conditions.Congrats! We ordered our Hawk Shell 2 weeks ago. Your setup should be sweet. The anticipation is killing is!
I say 265s because your are going to be heavy and I think 15mpgs is optimistic.
Good morning, sounds like you are well prepped for the a great trip. I live on the Peninsula as well and would love to chat about your itinerary. I'm leaving in Oct 2019 or Feb 2020 for an around the world trip in a Merc 1017. Send me an email: 2009BMW@Gmail.
Martin
For what it is worth I drove a similarly heavy first gen Tacoma (3.4 V6 with 5 sp manual) with a Callen Camper throughout Baja for 5 months with 235/85r16's.
I never needed more clearance than those tires provided and I drove down some pretty horrible roads.
Retrospectively I wish that I had re-geared even with the 235's as in first gear I had to let the clutch slip a decent amount when starting off going up hill or in stop and go situations.
I would think alot about GVWR on your Tacoma (try and keep things as light as possible). Yes they are solidly built trucks but they are only engineered for so much. I had a rear wheel bearing go out on my on my trip and had to replace all of my front end bushings when I got home and my truck bed started to fail/crack where it connected to my frame at the two front locations (I had a welder in Baja make some bomber brackets to remedy this). All in all the truck did everything that I asked of it and drove through some places I was shocked it made it through without getting stuck.
I averaged around 13-14 MPG's with a non aerodynamic heavy camper set up FWIW. My range was just over 200 miles with the stock tank and 300 miles with 10 gallons in Jerry cans.
I now have a 96 F350 with a FWC Grandby on the back. Yes it can't get everywhere that my Tacoma could but it is less tiresome to drive long distances, I am way under GVWR and I have an 800 miles range.
Not sure what your budget is but I wish that I had spent more on traveling and less on my truck/ mods.
Just my two cents.
Enjoy your adventure it sounds absolutely epic!!
I have an 11 Tacoma on 255/85 and no matter what i get 13 at the most
I would suggest more than 1 spare fuel can but you can buy that anyplace, as for tires go with a size that is common amd eaay to find. If you loose a tire and need a replacement a 35 will be hard to find. 31 to 33 way easier.
Quoted for truth....it's the one things I've learned over the years as well.
We have budgeted for a complete but not over the top build that will be both comfortable in capable in most situations we will encounter will going around the world along with enough runway for us to complete the journey and enjoy ourselves during that time.Quoted for truth....it's the one things I've learned over the years as well.
I wasn't insinuating anything, everybody's disposable income is different and relative to some of the big custom $XXX,XXX trucks yours is truly a 'budget' build!We have budgeted for a complete but not over the top build that will be both comfortable in capable in most situations we will encounter will going around the world along with enough runway for us to complete the journey and enjoy ourselves during that time.
Next upon the install:
-BAMF skid plates and rock sliders
I have decided to only run the BAMF main engine skid that made out of 0.250in thick steel. My thinking here is that the engine/oil pan hang low relative to the transfer case and transmission so I should have strong protection from any critical impacts while only adding about the same weight as full aluminum skid plates (~75lbs).Looking good so far.
It looks like you're going to need to keep a close eye on weight. If you want full skid plate coverage and don't plan on bashing the truck too hard, 1/4" aluminum skids will get the job done and save quite a bit of weight over 3/16" steel. It's also much easier to work with aluminum skids when you need to remove them.
That'll work. Tagging the oil pan on a rock would be a bad day.I have decided to only run the BAMF main engine skid that made out of 0.250in thick steel. My thinking here is that the engine/oil pan hang low relative to the transfer case and transmission so I should have strong protection from any critical impacts while only adding about the same weight as full aluminum skid plates (~75lbs).
We will probably not do any rock crawling or "black diamond" wheeling seeing as our rig needs to make it around the world in one piece. Instead we are trying to balance weight with durability and cost as it is rather easy to go down the modification rabbit hole if you aren't careful.That'll work. Tagging the oil pan on a rock would be a bad day.
It really comes down to what you plan to do. Many people run without any armor past whatever Toyota calls their tin splash shields. I have 1/4" full aluminum armor to keep from knocking a hole in the transmission or transfer case, and having protection over the fuel tank makes it more difficult for a moron to drain it. Judging from the dents & scrapes, I'm getting my money's worth.
Since you're already dealing with Jerry, you may want to take a look at his BAMF rear spring hangers & shackles. With the weight you'll carry and where you're going, that might be a good place for reinforcement. Your Dakar springs may need some work to fit the shackles, though.
