Toyota Diesel Firetruck Dyna 200 only 8700 miles
llaskin
1986 Toyota Diesel truck with 8700 miles. It is essentially new. The rear seats still even have the plastic covers on them. The gross vehicle weight is approximately 5000kg/11000lbs. It is a dually that is very heavy duty. It has dual engine brakes. The engine is the Toyota 13B. This is the direct injection version of the renowned 3B which was sold in the US, so many parts are available. Arguable one of the top Toyota diesels with all the advantages of direct injection without any of the electronics of a modern truck. 5-speed. New Tires. New fluids, belts, filters, battery. In Japan these trucks have to go through very rigorous regular maintenance and they do not use salt on their roads, so it has no rust. This truck is from Japan (JDM), right-hand-drive, with all of the proper importation paperwork. It has a clear Montana title and is currently in Helena. You can keep it as a firetruck or take off the pump equipment, which just bolts onto the frame, and add whatever bed you like. Here () is a sample of another firetruck with this aluminum bed (https://www.uteltd.com/) on it so you get an idea of what it looks like. It could easily be used as a tow truck or a dump truck. It has plenty of torque but the transmission is geared for heavy loads which limits the top speed. You can cruise on the highway at around 60mph. I will deliver it anywhere for a fee. $16450
DaveInDenver
Middle Income Semi-Redneck
States 4WD on side of truck in picture......?
The video I understood not to be the actual vehicle for sale but an example of what is possible. I agree, truck featured in the video is 4WD and obviously has manual hub locks. It also has 6 lug wheels, typical of older 4WD Toyotas.
I don't see the 4WD decal on the truck in the photos nor do I see hub locks. To me the front wheels look like they just have plain hub caps implying to me it's 2WD. Not sure about a transfer case shifter. It's possible it's a full time 4WD and has 5 lug wheels like newer 79 or 100 and 200 series trucks. I'm just curious is all.
4xCoffee
