Been thinking about power sources. My thoughts:
- I plan to leave home w/ the batteries fully charged via shore power. Hence I want a solid charger. I'm leaning towards Sterling Ultra. Fully programmable being the biggest factor. I don't expect to be on the road more than 4 weeks at a time.
- I plan to have solar. I prefer this be my main charging source. They are also great at topping off AGM batteries which is the stage that takes the longest for a full/healthy battery. AGM...because that's what the trailer comes with. I'll go with it until I'm ready for LiFePo. ps-Sterling handles LiFePo as well, so I don't need to get a new charger when that happens. LiFePo charge profiles are very different vs AGM.
The next step is what do I do when solar isn't cooperating (weather) and I need to get a good bulk charge (or complete charge) back into the batteries. A few options:
1. Truck w/ B2B charger. Don't like this idea for a few reasons:
- it creates additional load on my tow vehicle.
- for it to achieve the desired outcome, I'd have to run my truck for a considerable period of time. that means either a long road trip to the next destination or I start my TV and let it charge painfully slow. Sometimes I wonder if people using these actually check their output. Voltage drop can be a killer.
- unless I'm planning on connecting to the trailer's Anderson plug from the front of my TV (less cable), I would expect to need rather large gauge wiring, and I don't think the charger would ever truly get the batteries fully charged. Also, then what would I do when driving down the road? A second cable run to the rear of my TV? naaa. Neither strikes me as very efficient.
- I really consider this solution akin to solar, perhaps a bit better. If I was going to do anything, I'd probably just go w an ACR (simple/less expensive). Once the truck battery is fully charged, the ACR would allow a charge to go to the house bank.
2. Generator.
- noise. don't like noise. but running my truck isn't quiet either, (nor is it very efficient as a charger), and w/ some smart shopping there are some relatively quietER products out there.
- weight. not as concerned here as I want a relatively small generator.
- fuel. do i really want to deal w/ propane and gasoline reserves? naaaa. one's enough.
So I've arrived at the idea of a portable propane generator. I wouldn't need to lug around extra gasoline and I already have the propane tanks.
1. What's the downside (other than occasional generator maintenance)?
2. Any particular LP generator one would recommend?
3. Anyone doing something similar?
Thanks!
2. Generator.
Thanks!
