Moog CC880 on 2014 E350?
Surffj62
Can’t seem to nail down if they fit a 2014 EB or not. I’ve read they fit all years.
Rock auto says CC81368 are the ones I need.
I’d like the extra bit of front lift I’ve read about.
Raul
They do fit. CC 860, 860s, 880, 880s!.... depending on your engine weight they lift more or less. 880 is usually the best option for the V8 gas and the 880s for v10 and diesel.
Chassis wise, I’ll venture to say that any thing from 92 to 2014 will fit.
Bikersmurf
CC880 is the P/N. The P/N Rock Auto gave is for a different spring.
I’ve not read all of the following thread...
So if a guy wanted 2” of front lift on a 94 E350 with a 5.8 gas motor he should go with the CC880? Have heard that CC880S is what everyone is doing. Thanks I’m advance
spazegun2213
you'd be hard pressed to get a real 2" lift on the 880 with a 5.8. 1.5-1.75" is more reasonable unless your running super light up front.
The 880S will get you 2" (maybe closer to 2.5") but the increased rate makes for a harsher ride. That said, I've never ridden in a V8 van with 880S springs. I'm putting 880 springs on my v8, and if I want more lift I'll use a small spacer
gp01
