Arizona: 1991 Land Cruiser 1HDT HDJ81 (Fully Built For Travel)
MattScott
Approved Vendor
2003769
Pictures HERE!
I spared no-expense building this vehicle, and due to my vehicle ADD, I’ve decided to move onto a sports car and this must go. The concept behind it was the “ultimate” travel machine, built to tackle any terrain thrown at it, while still being comfortable on the highway and returning great fuel economy.
Driven conservatively the vehicle has over 1000 miles of range and could be driven around the world tomorrow without any concerns. All replacement parts used are genuine OEM Toyota, and the best parts in the world for upgrades were imported directly from Australia at great expense.
This vehicle was completely stock in August of last year when it was “mechanically restored” by Land Cruisers Direct (I have receipts), and then modified by Keith’s Garage in Grand Junction (one of the best Land Cruiser mechanics in the country).
Absolutely no expense was spared, with massive amounts of money spent on preventative maintenance. It will do 90MPH on the highway if you ask it, with a conservative amount of boost that has NEVER exceeded 17PSI.
The engine bay is immaculate, as is the underside of the vehicle. Please note that it is a 28 year old 4WD vehicle made to go off-road, it does have the occasional scratch, bump, or bruise, but I consider it to be in great shape for the model year. The interior components that cannot be replaced with new parts do show some wear, but are all clean and functioning. A/C is ice cold.
PRICE: $42,500
Contact: matt@adventure-imports.com
TEXT ONLY: 6308777297
211,XXX KM
Factory Locking Differentials (Front, Rear, Center)
Factory Ice Box
Factory Sunroof
King Shocks - 2.5-inch remote reservoir with compression adjusters and internal bump stops ($3500)
Custom Scheel-Mann Seats with Massage, Heat - upholstered in custom camira wool ($6000)
OME 2-inch lift springs ($500)
5X 285/75-R17 Falken AT3W All Terrain Tires ($1500)
5X SCS F5 Bronze Wheels 17-inch ($1000)
Webasto Thermo-Top C Diesel Heater ($2000 with custom install)
MSA 4X4 Drawer System ($2500)
MSA 4x4 DS40 Drop Slide ($800)
MSA 4X4 Fridge Barrier ($400)
Engel 45L Fridge ($900)
HPD Top Mount Intercooler With Fan ($1500)
G-Turbo Grunter Xtreme Turbocharger ($1500)
Beaudesert 3.5 Inch Dump Pipe ($500)
Beaudesert Turbo-back 3-inch exhaust ($1500)
Long Range Automotive 24 gallon sub tank with OEM dual filler neck ($2500 installed)
2X Optima Blue Top Group 31 Batteries ($450, less than one year old with warranty)
Rhino Rack Pioneer Platform Roof Rack ($1000)
Eezi-Awn Swift Awning ($500)
100W Overland Solar Panel ($250)
Victron 75/15 Solar Regulator with Bluetooth ($100)
Kaymar Dual Swingout Rear Bumper ($3000 installed and shipped from AU)
TJM front bumper ($750)
Livid Hyperdrive MKII Driving Lights ($1000)
Switch Pro SP-9100 ($500)
MAXTRAX MK2 with rear wheel harness ( $300)
Slee HD Tie Rod and Drag Link ($300)
Ironman 4x4 Adjustable Front Panhard Bar ($150)
Delta VS Panhard Relocation Bracket ($150)
Toyota OEM 80 Series Snorkel With 70 V8 Head ($1000 Installed)
Front Recovery Points ($100)
Slee Extended Stainless Lines
EGT/Intake Temp/Boost Gauge
Total Aftermarket: $35,000+
Mechanically Restored (All work recent within 8,000 miles)
Over $15,000 spent in mechanical restoration (receipts included) using all OEM Toyota Parts
Brand New OEM Toyota Steering Wheel
USA-Spec front brake upgrade (new calipers, larger rotors, new pads)
Brand New Master Cylinder
Rebuilt Front Axle with new wheel bearings
Rebuilt Rear Axle with new wheel bearings
New Front Control Arm Bushings
Landtank Caster Correction Plates
Engine Rear Main Seal Replaced
Transmission and Transfer Case Seals replaced (input, output)
Rebuilt Injector Pump
Rebuilt Injectors
Rebuilt front and rear driveshafts with OEM U Joints
Brand New OEM Toyota Tie Rod Ends
Brand New Headed Fuel Filter Pump
Brand New OEM Toyota Radiator
Brand New OEM Toyota Water Pump
Brand New OEM Toyota Timing Belt
Brand New OEM Toyota Coolant Lines (even going back to the rear heater)
Brand New OEM Toyota Blue Fan Clutch
Brand New Bosch Upgraded 12V Starter
Brand New Bosch Upgraded Alternator (120A)
Rebuilt AC lines
USA-Spec OEM Toyota transmission cooler
Brand New OEM Toyota Manifold and Turbo Gaskets, Manifold Bolts, Studs
Brand New OEM Toyota Intake Gaskets, Bolts, Rubber Washers
All-new exhaust bushings
Pictures HERE!
MattScott
Approved Vendor
What mileage do you get on average, daily driving?
I'll respond with my worst fuel economy, which is doing 80+ mph in Utah. In those conditions I see 17-18.
RPM and speed are what kill fuel economy. We saw 25 one tank in Baja, where we were cruising on Mex 1.
Timcampsallover
Tree Top Flyer
Not bad. Nicely prepared rig. I’m planning to sell my Tacoma and would consider a land cruiser like yours but I doubt yours will still be available. It seems to be a really well thought out and executed build.
MattScott
Approved Vendor
Too many people wasting your time, or do you just want to hold on to the rig..?
No one was wasting my time, I just don't think I want to sell it.
I'm too far deep into this vehicle financially to let it go right now, I'll just wait a year or two for 80s to appreciate more.
