Sprinter Camper Van. Pure Luxury. 3500 extra long 4 Season, Generator, Seats 8-10 in colorado
kevinclark
2013 Freightliner Sprinter camper.
Video walkthrough:
If it's listed it's for sale.
No trades, not renting, no services.
My contact info is: Nineee Sevennn Zerooo, 676 fourrr Seveen 57.
The van has never been in an accident, it is very well kept. It's been stored or protected from the elements. The paint looks brand new! Oil changes every 5,000 miles, new tires. 105k miles on van
Unlike most campers, the interior is created with a fully welded internal frame for all components. This increases the strength of the entire vehicle.
All the wood inside is solid maple hardwood. You will not find this on any other camper. The wood alone was 6k. The maple is covered with 20 coats of marine grade lacquor. Created like high end yachts.
All interior walls are insulated with r32 multi layer foam and incased in wood.
All the walls and door panels are covered with padded automotive grade leather. The window shades and bed/couch cushions are made of the same leather.
Fresh Water: 56
Grey Water: 32
Black Water: 32
LPG Capacity: 20 (2)
Water Heater: 6
Furnace c/w Elec. Ign: 30000BTU
Refrigerator 3 Way: 6
Air-conditioner 13,000 btu
queen-sized bed
hing door on bathroom that blocks off the bathroom area for privacy. Also blocks out the driving area to create exterior privacy. It keeps the heat in the camper area when it's opened.
Keyed exterior compartment doors
Thick radius 4-Season insulated storage compartment doors
Windows - Black Frame Dark Tinted. They have screens and open to allow air movement.
Lots of storage. There is 7' x 2' of stoirage under the seats. Large upper cabinets with locking and strut assistance to keep them open.
Night shades for all windows. Padded and insulated. They snap on creating a blackout. They also keep the heat in on cold nights.
Solid maple flooring.
Padded leather on interior walls.
Limo style seating turns couch into queen bed. Also folds up creating two additional bunks.
Couch cushions are 4 in memory foam. Very comfortable to sleep and sit on.
TV Antenna - Digital Concealed
Seven-cubic feet double door 2-way refrigerator
Stove Cover corian
Range with powered w/Fan and Light.
Oven propane
Systems Control Center
Large counter tops with large double bowl sink and high neck faucet and spray hose
Sink cover
Dual 20 LB Propane Bottles w/auto change over valve
Thermostatically controlled ducted forced air furnace with auto ignition
Fresh and waste water systems
Fresh water tank with lockable freshwater fill
4-Season holding tanks
Water Pump - Shurflo Quiet Revolution
6-gallon DSI gas water heater w/ insulated tank
Systems service center monitor & switches panel
Low point fresh water drains with valves
Water heater bi-pass / Winterization valves
Single termination point for waste tanks
Outside Shower
Black Holding Tank Flushing System
Enclosed, insulated and heated tanks
Bathroom
Shower-One Piece floor to ceiling fiberglass
Fresh water flush toilet
Towel bar/ring
Electrical
45-amp electronic power converter/battery charger
Furnace-30,000 BTU DSI
Easy access distribution center
110-volt, 30-amp power cord
110V convenience outlets
110V GFI-protected outlets
12V Power ports by sink
LPG gas detector
Carbon monoxide / smoke detector
Fire extinguisher
Operational
Fresh Water Capacity: 56 Gal. Internal heated tank.
Gray Water Capacity: 32 Gal.
Black Water Capacity: 32 Gal. Internal heated tank.
Air Conditioner BTU Rating: 11,000
Furnace BTU Rating: 18,700
Water Heater Capacity: 3 Gal.
Mercedes Sprinter Options:
GPS
Heated and electrically adjustable exterior mirrors
Cruise control
Rear view camera
Wet Wiper System
High Beam Assist
High Performance Headlamps
Heated Seats power adjusting leather bucket.
Multi-Function Thermostat/AC/System
All Safety Options
Rv Options
Electric & Propane Heater
upper power cabinet
2 AMG Deep Cell Batteries rear. 1 AMG Deep Cell up Front all brand new.
Generator rear onan 3500 Powers the coach batteries and front battery.
Pantry: Huge pantry with shelves for plenty of space
Corian countertops and sink. The drivers side couch support folds up and creates a 6.5 foot counter top.
Stove - 3 Burner Propane Cooktop
Armoire- Additional storage cabinet for hanging clothes and shoe storage.
Television: 32 in. flat screen HDTV on rotating bracket + DVD player and theater system
Wheels: 16 in. aluminum polished with steel spare
Outdoor hot and cold shower
Dvd,cd,navigation with front and rear speakers in camper.
Chassis Model: Mercedes Sprinter
Exterior Colors: Metallic Gray
Sleeping Capacity: 2-4
Awnings above sliding door, Awning Length: 13 Ft. 2 In.
Engine drivetrain
Engine Type: 3.0 L, CRD V6 Turbo Diesel Blue-Tec
Fuel Type: Diesel
Transmission: Automatic, 5-speed, Heavy Duty
Measurements
Overall Length: 24 Ft. +/- 4 in
Wheelbase: 170 In.
Wheel/Tire Size: LT215/85 R16 E Black Wall Dual Rear (all brand new )
Exterior Width: 6 Ft. 8 In.
Interior Height: 6 Ft. 3 In.
Trixxx
What kind of for sale post on a vehicle doesn’t include the miles? Makes you wonder what else they aren’t disclosing..
llamalander
R-32 foam insulation, so about 5" all around the van? Probably worth a million bucks! My nine closest friends would love me...
kevinclark
Yeah, closer to 4". Double layer Thermal Insulation Sheet and spray foam in the areas I couldn't get to. 2 layers of wood and Reflective Foil Insulation Sheet on the floor. Double layer leather snap blinds with insulation inside.
Henrybrowne
