6/13/19:
With the lift, diff bushing, cv refresh, spare tire mount, etc. now completed; I took Yoshi over to PepBoys to get the following done:
- Load E 31.5" Nitto Terra Grapplers changed to Load C 33" BFG KO2s
- OEM Wheels changed to Toyota TRD Offroad 17x7.5 Wheels with hubcentric wheel spacers and Toyota wheel locks.
- New VDO Redi TMPS Sensors since all my existing TPMS sensors are kaput. Toasty didn't want to deal with it when he owned the truck and just put a boot over the light bulb haha
- Lifetime Alignment
Buckle up for a story:
I dropped the car off around 10am and got a call at 3pm saying it was done (eeeek, good thing I didn't wait for it). So I get there and I get some good news and some bad news. The good news is that they got the wheels and tires mounted and balanced and alignment done. The bad news is that they couldn't get the TPMS sensors to work with their Snap-On TPMS tool and also that the truck has a shimy at speed which they think is just par for the course with 33s or possibly from a worn steering column.
I had already replaced 2 out of the 5 tpms sensors a few months back at Discount Tire and their TPMS scanners couldn't communicate with the Mitsu computer either. I know Mitsu has it's own MUTT protocol that only the dealer can read but Continental says their
 universal VDO Redi Sensors fix that and allow other popular scanner brands to be able to program them. Now in fairness, the scanner that Discount Tire uses and the Snap-On one are not listed by VDO as scan tools that will work with these universal sensors so I don't blame them for that and wasn't expecting them to work. The thing is PepBoys said they had a ATEQ TPMS scanner, which is on the list of approved VDO redi sensor scanners, but it was lost when I had my appointment so they told me to just swing by a different PepBoys and they'd do it for me. No biggie. They also said the wheel locks wouldn't fit on these new wheels which doesn't make sense to me since they are genuine Toyota ones that Toyota says fits all 4runner wheels but I'll investigate that one later. Again, no biggie.
The bigger issue is when I drove the car home and it was pulling hard to the right and had an aggressive shake in the steering wheel above 60mph. I didn't buy their reasoning of it's just the nature of 33s because I've had a Gen3 before with 33s and it didn't have this horrible vibration. And I didn't buy the argument that it was my steering system because the vibration and pull to the right didn't exist with the 31.5" Nittos they just took off.
So at this point I'm suspecting 3 possible things: 1. Bad Alignment 2. Bad Wheel Balancing 3. The brand new spare that I just had put onto the driver's side front position is 2/32nds taller than the other 3 tires (5 wheel tire rotation) and that could be causing problems.
Oh well, no time to worry about it now. I was moving to Flagstaff in 5 days and had a ton to do. I was planning on taking my other 2 vehicles up on the first trip and then coming back to get Yoshi a week later so these problems would have to wait.
6/24/19: Back in town after the move up the hill and out of the valley of the sun, I set up an appointment at a different PepBoys because I wanted them to not only check PepBoys #1's tire balancing and alignment job because of the vibrations and pull but also because I needed the TPMS sensors reset and they had an ATEQ scanner that VDO says would work on Monteros with their universal sensors.
I decide to wait at PepBoys for this service since I'm thinking it should only take an hour, maybe two, to check the alignment and tire balancing and program the sensors. Wrong. 3 hours later, the tech comes out and shows me my passenger side lower control arm camber adjustment bolt. He points out that the threads are completely stripped and that the nut was just barely hanging on there. My heart instantly sinks because I'm used to working on Monteros and know that the odds of being able to find another one of those parts same day is very slim and I had to finish my move to Flagstaff with this Montero, towing a trailer, the next morning. He explains that this solves the issue of why my truck was all over the place as this camber bolt was not tight at all and also lets me know that none of the tires were balanced properly.
So I make some calls to a few of you to try and find this camber bolt but no luck. None of the dealers in Phoenix have the camber bolt and so it will have to be shipped in which doesn't help me much.
The manager of PepBoys #2 is pissed, he says that PepBoys #1 clearly went crazy with the impact gun and destroyed the bolt, that he's now tied up a tech for over 3 hours working on their mistake, will have to pay for a new OEM camber bolt, nut, and washer + shipping, and even worse that mine was the 2nd car brought into his location that day to correct problems from the PepBoys #1. So he called over there and gave them a what for.
We brainstorm and can only come up with 2 viable options: A - delay the rest of my move and put my life on hold for another 3 days for the part to arrive. B - weld that nut back on so I can make the drive but the car won't be in alignment and the camber bolt will be able to rotate freely, possibly causing some unusual steering wheel behavior.
I opt for option B - weld that nut on so I can get the hell out of Phoenix in late June. They didn't attempt the TPMS reset with all the other crap going on, 4 hours later I was out of there:
PS - Always check out a shop's work before you leave their premises. When checking out this weld, I noticed they didn't unclip my new steering rack boots when they did the alignment. Luckily they were all brand new and had no problem twisting but if they were older I'm sure they would have torn right apart.
6/25/19: I had to move the rest of my stuff which didn't fit in the 26' moving truck last week up to Flagstaff using my small 8' enclosed utility trailer. The trailer only weighs 1,000lbs empty but I had it packed to the gills and estimate it weighed around 2,500 lbs max. I hooked it up to the Montero which had a noticeable clunk in the front end from the janky camber bolt.
The trailer was sitting a little nose high. Normally, I'd probably not worry about it but with the trailer being fully loaded, the steering in the vehicle not at 100%, and the trip taking me up perhaps the most treacherous stretch of interstate in the country I figured I should play it safe. So I went to Harbor Freight and bought an adjustable hitch to help bring the trailer back down to level.
Problem is, I hadn't loaded the back of the Montero yet when I made this decision. I totally forgot that I had a ton of stuff to put back there. Ok, maybe not a ton, but at least 1/4 ton. Seriously, I estimate that I put around 500lbs of gear in there, 80lbs of it was the winch that I hadn't been able to install in the bumper yet.
So I load up the Montero the next day with all this gear, hook up the trailer on the new adjustable hitch and even in it's highest position it was now a little nose low. I figured it was better to be nose low than high to avoid trailer sway but thinking back on it that was the wrong decision. I should have remembered that I didn't have my gear in the back of the montero on the first test and had I tried it with my standard hitch the trailer would have probably been close to level.
Now, don't freak out because the picture makes it look worse than it was, kinda. The front looks waaaay higher than the rear because the front springs are oversized for the amount of weight up there since the winch and bigger battery are not installed yet. Even with an empty truck, the front sat up higher because of this.
I know the dangers of towing hitch heavy and unbalanced and like I said, I should have stuck with my original hitch, but the good news is that I was well under towing capacity at 2500lbs, and probably still under the max tongue weight of 500lbs. Yoshi cruised up from 1,200 feet to 7,000 feet without issue. I kept it slow on the big hill climbs at around 55mph and even on the downhills I kept it at 65ish. I even had to do 1 hour of dirt road driving because the I-17 was closed for an accident (as it is every weekend) near Camp Verde so I took Cherry Road around the closure. Kind of harrowing to tow this trailer over and down a mountain on a narrow dirt cliff road but I kept it around 5-15mph and made it without any real drama. Truck handled great on the asphalt even with the nose up, the dirt road was the only white knuckled part. Also, I noted that I could have gone faster up the big hills which was encouraging since I'll be buying a 2,800lb camper next year (3500 when loaded). Up the big hills I was going 55mph at 4500 RPM and I felt that if I had dropped it down into 3rd it would have gone  65-70 no problem but I didn't want to put that kind of strain on the car on this trip.
