Storage Box
PSea
Wondering if anyone can point me in the right direction. I want to mount a storage box on the rear of my popup camper. It needs to accommodate rear tail lights. dimensions are roughly 72" x 24" x24".
Any suggestions? I suppose if it doesn't have cutouts for lights, I could have them cut out after purchase.
shade
Do you have a few photos of the rear of the camper?
I added some storage to that area by mounting a piece of wire shelving across the frame. It worked well for small things, but they weren't kept clean.
PSea
Planning to remove everything on rear. Spare tire will be moved to the tongue. Trailer has too much tongue weight even with the empty storqge box on front which will be removed. Doesn't work on the rear in case anyone was thinking that.
shade
If you have a battery box and/or propane tanks on the tongue, you could relocate them to the rear to lower tongue weight.
PSea
Yup. Well aware of that. All storage being moved to rear. Just need a storage box. Git the rest figured out.
shade
I've had good luck with Contico TuffBins being secure, weather sealed, and they're reasonably priced. You'd have to check out the dimensions to make sure there was enough clearance at the rear to open it.
PSea
I want the door on top. Wondering if it could be mounted that way to accommodate.
Also now considering
1. A shorter box which would be offset to one side and then mount propane tanks to the other side and/or..
2. Create a space between the trailer and new box where 4 jerry can mounts would reside. 2 gas & two for water.
