M101 off road camper for sale
kevinrx7
Thinking about moving on to a small tag along, so time to sell this home made camp set up.
M101a trailer that had been converted. Surge brakes removed, stock drum brakes removed. Running the stock axel with 8 lug hubs. 265/75/16 fierce attitude tires on aluminum rims with plenty of tread and matching spare. Tounge has been extended with removable lunette. Landing leg swapped for swivel/ adjustable tounge Jack. Wiring converted to 12 volt, led tail lights and side markers. Interior has been raptor lined. Exterior is just rustoleum for easy touch ups. No rust on trailer. Tabs added to tailgate so that the gate chains can be used in a level position.
Tepui autana ruggedized with annex in excellent condition. Memory foam topper added to factory mattress. Wife made custom quality sheet set to fit, with pillow cases. Additional sail track added so you don't have to remove travel cover to install annex. Tent is mounted on thule sportster height adjustable racks. I have always just left the racks at annex height without issue.
Home built kitchen is 8 feet long and slides out on converted pop up tent trailers bed slide outs. The kitchen is overkill because we like to eat well when camping. Plywood construction with stainless steel counter. 3 drawers with large cabinet on 1 end. Sink and faucet. 15 gallon water tank and electric pump.
Tounge box holds 2 lawn mower size 12 volt battery, shut off switch and panel with volt meter, USB ports, 12 volt port and switches for the led lights and water pump.
Led rock lights under trailer for camp ambiance. Lighting in tent with fan, annex. Under cover on kitchen end and inside tounge box.
Trailer cover is just made of plywood that hinges up on either end for access. Keeps things secure and 95 percent dry. Strong enough to walk on makes tent set up easy.
Spare tire mounted on top of cover, saves space inside trailer for all the other crap we drag camping.
Height adjustable pintle hitch included in sale.
I think $6000 is a fair asking price.
Located in Brewer Maine, would considered delivery throughout New England.
Having issues getting photos, will post more soon.
Sent from my SM-G960U using Tapatalk
kevinrx7
I forgot, also has a 20# propane tank mounted on tounge box. Will include table top grill and large side burner with splitter and extended hose
kevinrx7
Would like to sell as unit. I'll let you know if I change my mind. Thanks for the interest.
jtrak83
Impressive build, nice job. I am looking to get an M101 soon and do similar things. Do you recall what it weighed in at with all your modifications? Thanks
gp01
