New Trailer idea I’m working on
Mjaylq
I got a crazy idea for a Jeep Trailer the other day. I thought somebody might like what I’m doing right, or wrong. I will post photos as it progresses. I started about a week ago in my spare time.
Mjaylq
What's the "crazy" part?
Maybe un-typical would have been a better descriptor. I am going to build a trailer that in some ways is similar to many of the military ones we see, yet also quite different. The two sketches are what I mean. In the center of the trailer is a smaller tub then you see on the typical military trailers. On the outside will be six large ammo cans, or “rocket boxes” that will hold my stoves, cook kits, camping gear, etc.
Mjaylq
I have had this tub kicking around my yard for about a decade. I figured it is time to put it to use. This will be the center portion of my trailer surrounded by large ammo cans. The rust is just surface and should clean up nice.
Mjaylq
If I can do third grade math then six ammo cans should fit just right around this tub!
Mjaylq
Got the tongue welded in tonight. Hopefully start on springs and axle tomorrow.
Mjaylq
Here is a super rough idea of the future trailer lay out.
chunko
I like it. I like the modularity so you can have ammo boxes with different contents for various purposes: set of boxes for general use, a set for hunting and camping, another for hardcore off roading etc. Very nice!
What are the details on the axle, springs and tongue.
Sent from my Pixel 3a using Tapatalk
Mjaylq
I put a 3000 pound axle under it. The tongue is 2 inch square tubing 1/4 inch thick. Then I welded a 1/4 X 2 inch flat bar under it to stiffen it up. I doubt it was needed, but peace of mind. I took it on a long trail last weekend and it tows real nice!155EA40C-550C-4D06-8991-3292516ED088.jpeg
Mjaylq
Whats the dimensions and thickness of the steel you used for the rest of the frame?
The main frame is 1 X 3 X .125 tubing. It is reinforced with 1/4 inch wall where the shackles and tongue weld in. It is also gusseted in several areas.
DanoWall
