Nathansharkey80
So I was able to mount 285/65/R18 tires to my Range Rover L322 2012 5.0LV8 model using 18” compomotive wheels. No rubbing found so far. Also I was able to install the 5th wheel inside under the rear cargo floor where the spare tire is normally installed once I let the air out of the spare tire. I used Kumho Road Venture AT tires from Japan. Has anyone ever used these tires before? They appear to be a pretty aggressive all terrain tread. They are 8 ply load range D and this combination has already improved the smoothness of the ride compared to the wheel tire combo I had before which were 20” wheels.
