Intech RV
Ordered this trailer dolly...man a real lower back saver when moving our Flyer in and out of the garage. Maxxhaul 12” tires via Amazon Prime $50.00. Some assembly required... inflate tires to 30# done. Works perfect for my needs. I only wish it was made here and not China. I digress.
Haha yeah, but when you have very little clearance to get a Pursue backed in on a back wall with only 3” to spare precision maneuvering is everything, at least for me. My Pursue 13’9” my workshop 14’3”. The dolly makes it a breeze.
Pic of where trailer just fits in my shop. ? love having it garaged. The elements are relentless.
Comes in handy with my Aluma trailer also in lower basement garage. Best $50 I ever spent.
dreadlocks
Ive got less than 1in of clearance on each fender to get it through my gate, and I back it in and pull it out w/out any help anymore, on first try.. you just needa install bumpers on that back wall :p
I actually have pool noodles on the back wall..haha. They work perfect. Maybe someday I will be as good as you ? just kidding.
XPEL self healing paint protection install...6 hrs for the entire camper. Very happy with the fit and finished product. This installer has done several cars and trucks for us, he does awesome work. I use Plexus cleaner/polish to keep the p/p looking great.
Garand
Not many changes...instead of the lift, you can upgrade to a Dexter 45 degree down axle and larger off road tread tires which I did. The lift kit can still be added later by the owner if you want a higher approach and departure angle. I actually have the kit, but have not decided whether I want to roll that way. If I go larger tires I may. There maybe other small changes IDK. We ordered our Pursue fully optioned. For the $$$$ it’s a nice minimalist camper.
I have a 2019 that I picked up this spring. Just hadn't seen what was changed for the 2020's.
I installed some Yakima round bars on the rack so I can haul my PA14, works pretty good as a mobile fish camp!
I replaced the tongue jack with an ARK 500 series jockey wheel. Made a load of a difference! Only issue is I had remove the tongue box to fit it. I replaced that with a smaller box that is just large enough to hold my hose, power cords, wheel chocks etc.
Eberin
@MrOffshore - Have you ever received inquiries to permanently install a bunk/shelf in the rear of a Pursue? This shelf would be for a 2 year old child to sleep. I assume you could drill right into the wall? or frame? i would just be concerned with the electrical wiring that is hidden.
dreadlocks
Anybody know of any Discover model available- new or used? Really need the ceiling height- thanks!!
Good luck with that, as far as I can tell they only made a dozen or so of em.. they changed name in middle of the run too so they might not all be listed as discover.. forget what they started out calling em.
latest pic in tow:
Linesman1776
