SOLD--2003 Toyota Land Cruiser--locked, lifted, armored and baselined
Jafrench
SOLD
Asking $25,000 OBO $22,500 and willing to deal
Purchased January 2016 from dealer in OKC w/ ~111k miles. 1 previous owner, listed as corporate vehicle on the clean Carfax report. Regular, routine maintenance (I have records from dealership ). Current mileage is 149,6xx. It will go up a bit over the next few days but hope to keep it under 150k until the new owner takes possession.
VIN: JTEHT05J232047871
Post purchase (March/April 2016) inspection and baseline done by Slee Offroad including:
-Front wheel bearing service
-Fuel filter
-Spark plugs
-Timing belt, front crank seal, idler bearing, serpentine belt
-Water pump
-Drain and fill diff, transfer case, engine oil
-Lube drivelines
-Transmission fluid drain and fill
-Brake fluid replaced, bleed system
-Air filter
-Grease driveshafts
-Drain and fill radiator, clean and fill reservoir
-Heater Ts
-Harrop E-Locker front and rear install with OEM switch
Mods:
-Cooper Discoverer AT/3 275/70R18 and matching spare w/ 30k+ miles on them
-Ironman Foam Cell Pro lift
-Nitro UCAs
-Diff drop
-Airlift 1000 rear suspension air bags
-Exhaust resonator delete
-Dissent aluminum front bumper
-Dissent rear steel bumper (OEM crossmember cut) w/ single spare tire swing out
-Trail tailor sliders
-Trail tailor creeper skid
-Gamiviti Expo+ roof rack with front light bar and rear lights (not wired)
-WagonGear tailgate lid
-Depo headlights
-Slee Group 31 battery tray w/ X2power AGM battery, mil spec battery terminals
-Slee stainless brake lines (rear installed, front supplied at purchase)
-ARB low profile drawer with fridge slide (passenger side, easily removable)
-Wits' End fire extinguisher mount (driver side)
-PFRAN interior LEDs
-YotaMD titanium key fob
-Weathertech floor guards front and middle row
-Switched auxiliary rear fuse panel with USB, mini Andersen connectors and/or 12v plug
-Bedliner'ed rear cargo floor 3/4" baltic birch wood base (allows use of 3rd row seat(s) with quick install/removal of drawer)
Recent (May 2019) upkeep/maintenance performed by 2001LC (100 series expert on IH8MUD):
-Exterior wash, clay bar and wax
-Interior clean/detail including leather clean/condition and carpet clean
-OEM idler pulley
-Tensioner bearing
-Differential drain/fill
-Power steering flush
-Re-torque spark plugs, head cover
-MAF clean
-Replace cracked air box vacuum line, PVC hoses, idle up control vacuum line
-Air filter
-Rear stainless steel brake lines install
-Brake fluid flush/bleed
Known issues (see pictures where applicable):
-Rear hatch rust (in the process of fixing this)
-Wheel arch rust
-Front passenger seat leather (tough/firm)--all other leather in good to excellent condition, no tears
-Keyless entry not working due to me haphazardly removing a bunch of PO wiring and getting overzealous (still have the needed electronics for it, just needs to be reinstalled)
-Replaced 2nd row overhead DVD player with OEM dome light but need to fab a little cover over the cutout in the headliner
-Although it's good enough for me, sound system could use a once over (PO wired aftermarket subwoofer which I deleted; ?new speakers, sub +/- amp), including recovering speaker grills
-Handful of cosmetic restoration items (grill chrome, console shifter bezel, plastic seatbelt hooks/stays, broken cupholder, etc.)
-Laundry list of upcoming recommended service per 2001LC:
Coolant flush, thermostat w/ o-ring, wheel bearing, axle bearing/bushing service, transfer case flush, lower ball joint, coil boot/seal kit
Jafrench
Hatch rust. I've sanded this down and have matching rattle can to respray it. I also have a pre-'03 color matched hatch that one could swap in instead (included in the sale)
Headliner dome light issue:
Jafrench
Undercarriage (sorry for the Rocky Mountain dirt/mud)--some surface rust in spots but overall good condition with absolutely no rot:
Jafrench
Some of the mods...
80 series locker switch for the Harrop e-lockers
Switched power ports in the rear cargo area:
3/4" baltic birch platform allowing use of ARB low profile drawer/fridge slide and 3rd row seats:
Superduty
Pardon my ignorance, what does "baseline" mean? I'm familiar with that term in baseball, but new to me with regards to cars.
Sent from my SM-G973U using Tapatalk
Jafrench
When one acquires a new-to-them used car, baseline refers to replacing all the fluids, filters, belts, plugs, scheduled maintenance that either wasn't done or is due, etc. See my laundry list in the first post.
So what should be done when one buys a used car will not need to be done with this rig, outside of the few things I mention at the end of the 1st post above.
Jafrench
Pics of the ARB drawer/slide included in sale (and would consider throwing the 63 qt Edgestar fridge into the deal):
Jafrench
Replacement hatch included in the sale (if the buyer wants it):
And the rust mitigation work I'm doing on the original hatch. A little more clean up, prep and paint and she'll be good to go:
