Extreme use Earthroamer
Trikebubble
Is there room for that on those logging roads or was there damage to your vehicle as a result? Curious as I've never explored any logging roads but sounds like it could be fun.
Their are pullouts on the logging roads, if you have the right radio and listen you will know when to pull over and wait. I don't, so I just drive with extreme care. Most logging trucvks are the regualr on-road ones and usually you have enough room to squeeze by. The large off-road ones do really take up 95% of the road, so you just kind of slowly pull into the ditch area and let it lumber by, then hopefully you can pull back onto the road after that. The logging trucks are in contact with each other and I believe will relay information on civilians traveling on their roads. It's a little hairy but well worth it when you find what is at the end of some of these logging roads.
al_burpe
Where I grew up in Idaho, it was advisable to have a cb when driving on logging roads. The road would have the station posted and mile markers painted on the trees. You would call out your mile markers for on coming traffic.
Todd780
OverCamper
So just call them out at random as you're driving or would you be in contact with oncoming traffic along the way?
Trikebubble
In BC, each road is given a specific fequency channel (I believe they use VHF or something like that). Their are large signs letting you know the frequcny channel to listen to, if you have the right type of radio (they don't use CB's here). The logging truck drivers will call either up or down and a certain kilometer marker on the given road to let other logging truck drivers know their location. Around here you see signs saying "Must Call 13-Down" (for instance) all over the place. Again, it's just part of life living here in BC. Logging roads will take you everywhere, so you just get used ot traveling on them, knowing where active logging is taking place, and be cautious.
shade
Good advice.
I spent a night at Wistaria Provincial Park while wandering north and ended up in an active logging area without a CB. I think that's the only time I ever wished I'd had one because the roads were well marked just as Trikebubble described. Fortunately, the roads were wide and the drivers were courteous and careful - the heavy rainfall probably helped.
AbleGuy
Officious Intermeddler
TnN, I can't speak for the Vancouver drivers, but the Idaho logging road drivers are a bit of a random sampling. Some of them are quite reasonable and others will run you off the road the first chance they get.
As a result, we will occasionally pre-ride a selected road with the e-Bike to make sure its not an active road before committing the big rig to a narrow, winding road which frequently has a 2k foot drop off.
Yup, it’s never been a good idea to try to play chicken with a log truck driver.
shade
The truly dangerous part is they may not be able to do anything, even if they want to give another vehicle room. Stopping a big truck with a heavy load on questionable terrain is similar to stopping a train. Swerving can be a very bad idea for everyone.
On roads like those, I consider myself a guest. Public or private, they're made and maintained for industry, not tourism. If enough people cause enough problems, use can be restricted.
AbleGuy
And coming down a steep hill, fully loaded, you cannot expect the truck driver to have much of an ability to quickly stop or zig around you. They’re usually going pretty fast too, because these guys are trying make a living. We have to respect that, whether we agree or not with what they’re doing out there.
Alloy
I drove pickups on RR (resource roads) for years but once I started pulling trailers on the RR I got a radio and licence. It is great knowing what is on the road...wish everyone pulling a trailer or with a dual wheel truck did the same!
The RR are radio assisted not radio controlled so there is no requirement to have a radio.
The 35 RR channels in BC are VHF. A CB won't work.
An operator has to be licences to use these frequencies but I've only heard or radios being seized when people abuse the privledge.
Fifteen of the channels are not to be used within 40 miles of the USA border. I think these are Military Auxiliary Radio Service (MARS) frequencies.
Each road (active roads for sure) will have a sign at the start (up) of a road. Some signs will list the call procedure. Due to the fact that some RR are numbers I call the name/number - then up/down - then the km.
A call list.
1. Number or name of RR you're on
2. Up - Down - Stopped - Leaving
3. Kilometer number you're at. Often one calls even going up and odd going down
3. What you are vehicle is. I call "Pickup with 5th Wheel Camper"
Vehicles going down have the right of way.
Everyone on RR with a radio will report vehicles without a radio.
If the road is not active or you find youself coming in at the at the end (down) of the a RR there may not be a sign.
Below are the RR channel maps. I keep a binder in glove compartment with the pages.
***The signs on the RR take precedence over the web site info.***
MUST CALLS are for sharp turns, single lane section of roads/bridges. A MUST CALL is a warning of dangerous road conditions.
There is no way a 100,000lb logging truck can stop. I know someone that dives them. On some routes leaving a cut once they roll over the edge there is no way to stop for miles. These routes will have KEEP OUT ACTIVE LOGGING signs.
AbleGuy
I wonder if there is a automatic timer on the forum that we can set so this topic comes up every 3 months as a matter of course?
That way no one has to remember "Oh, it's my turn to start the "large expo vehicle/rock crawler/offroad vs bad road butthurt pissing match" thread. It gets annoying when someone misses their turn and we have to wait a whole 5 or 6 months for it to come around again.
Great Quote.....so here’s the human assisted auto timer to re-set this entertaining thread, which is definitely worth re-posting to keep up the chatter....?
waveslider
Outdoorsman
Good deal, thanks Able guy. Which angle shall we take on this go around?
Will it be the "My truck is bigger and more expensive therefore its clearly superior...." angle or will go with the time-tested approach of "Even if I had the money, those things are far too big to do any REAL off-roading or rock-crawling so therefore they are a waste of money for anyone and should be banned from the planet - my Landcruiser is ************...."?
Maybe we'll get lucky and have both...
shade
If I wanted a house that moved, I'd live in San Francisco.
Sorry. I'm really tired and that's the best I can do.
goin camping
Entertaining thread.
Some guys here built their own. (That Air Force looking truck and the white one.) but not everyone can nor does everyone want to camp and explore in a Subaru.
And for those folks who cannot build their own. Companies have been formed to provide what those folks want.
I camp out of the jeep in the avatar. A Chevy AWD van I converted and a 1960 Airstream. I really like to camp and explore.
If I had yacht, private jet Bel Air mansion money. I'd have an Earthroamer. Looks damn comfy inside with enough non pavement ability to haul me all over the Mojave in comfort.
The beauty of it all is we all get to do what we want or can.
Alpina FG
They are great vehicles and a great option for those able to write the check. However I never saw a single one in Alaska, the Yukon, or the Northwest Terriotories when I was up there in my 18,500 pound Fuso 4x4. I'm not sure the data agrees with you on them being "the only way to go"
Does your FUSO actually weigh 18,500 pounds ?
oskarf150
