For Sale: 2001 Ford Excursion 7.3 Diesel 4x4!
Hellbender75
Up for sale is a 2001 Ford Excursion 4x4 7.3 Diesel! It has 271k miles on it with a clean title. I'm selling the truck because I have to downsize to one vehicle due to where I live. Truck is in great shape is very clean, rust free and has a clean CARFAX and was in Arizona, Nevada and California its whole life.
Has been well maintained complete with many service records. No trades please.
PRICE: $13,500 Or Best Offer - Located in Santa Clarita, CA USA
ENGINE, TRANSMISSION and MECHANICALS:
Engine is in excellant shape with no hard starts, no blow-by and no engine misses. Transmission was replaced about 80k miles ago and is still fresh feeling and shifts perfect. Driver side second row window motor needs to be replaced. That window is in the closed position. Vacuum lines to autohubs need to be replaced. No other mechanical problems whatsoever as far as I know.
UPGRADED OR REPLACED RECENTLY WITH ALL MAINTENANCE RECORDS: I HAVE SOME PICS OF WORK DONE
1)- Truck has been converted to a 2005 Excursion front end for a more modern look and better lighting. I still have all the original parts.
2)- Transmission was replaced approx. 80k miles ago at Champion transmission in thousand oaks, ca
3)- Dual DVD Entertaiment system professionally installed by stereoland in ventura.
4)- Radiator and waterpump replaced November 2015
5)- Power steering pump and hoses replaced 8/9/2018
6)- Left and Right upper and lower ball joints and inner/outer left and right tie rod ends W/ Alignment done at 8/9/2018
7)- 4 KYB MonoMax shocks and Bilstein Steering Dampener installed 9/1/2018
8)- New upper and lower radiator hose and degas bottle installed 30 days ago
9)- New Front and Rear Rotors and brake pads installed 4 months ago
10)-Coolant flushed 4 times and then replaced with Ford ELC coolant 30 days ago
11)-Riffraff diesel complete set of Charge Air Cooler boots installed 4 months ago
12)-Transmission temp, boost gauge and EGT gauge installed by previous owner over a year ago
13)-Fuel Bowl Rebuilt with VITON O-rings from Diesel O-rings 4 months ago
14)-New polyurethane Front Sway Bar bushings installed 9/1/2018
15)-New Diamond Eye 4" exhaust from the downpipe back with a jones turbine muffler installed 1/5/2019
PAINT, BODY and INTERIOR:
Paint is in decent shape and shines up well for a 18 year old paint job. 2 small dings on the truck. I have pictures I can send to show.
Carpet is in great shape with no holes, stains or weird smells of any kind. Cloth Seats are in great shape as well except side of driver seat which had a 4" tear that I hand sewed closed. Otherwise seats are clean, don't smell and look great. Although the pictures don't show it I DO have the 3rd row seat in great shape. 2 toggle switches installed on left side of dash that used to be connected to driving lights but are not used now. No tuners or chips installed.
Hellbender75
Thank you, I wish I didn't have to sell it. The highest mileage i've seen was right around 1900 rpms and 67 mph or so and I got 18.2 mpg after I had reset my lie-o'meter. Hand calculated it came out to be about the same, 17.9 or so. Strictly city driving I'm getting about 12-12.5 mpg and everyday use where I do more city then hwy miles I'm seeing 13.6 mpg. I've put on about 5.5k - 6k miles since I bought it about a year ago.
Hellbender75
That would be loads of fun but unfortunately I need the money and I am having to downsize to one vehicle for now due to where I live so I wouldn't have room. Thank you though for your consideration
Houie
