Favorite Tire Repair Kit?
drrobinson
I have an ARB Kit in the truck and used it two days ago on the street.
1” screw in-between the tread blocks. One plug and done, or so I thought. Another piece of metal on the other side of the tire was leaking when I re-inflated. Another plug and all was good.
I have previously used this kit once before. Same positive results.
1leglance
Sounds like ARB is a winning for a good basic kit, I do like my Extreme Outback for all the extra bits that I hope to never need (but have)
TantoTrailers
Can someone tell me whats special about the ARB kit as opposed to any other goo string kit out there? It looks the same or maybe I'm looking at a different kit...
Winterpeg
Biggest plus is likely the quality of the handles for the plug puller and reamer.
You don't want those things breaking in your hands causing injury.
Sent from my SM-G950W using Tapatalk
1leglance
Yes the handle is the nice thing, especially the extra ring they put on the plugger so it holds the gummy into the tire as you pull out the plugger.
Junkinduck
I’m a fan of the safety seal kit. Good quality tooling. Just used 5 plugs and a borrowed slime compressor to get my can am buggy home. Otherwise I’ve used the safety seal kit and the puma 12 volt compressor several times on the road with the camper. Can usually patch and be back in the road faster than getting the spare down. And go for the good fix when we don’t have the camper hooked.
Beowulf
Love the Extreme Outback kit for all the extras, but it was used to supplement the original Safety Seal kit. Honestly though, I've never needed more than what was in the old safety seal kit.
geojag
I picked up a "Tooluxe" kit off Amazon for $16. The tools are pretty much identical. I already had the other components of the ARB kit, so it works for me. The spiral rasp works surprisingly well.
  • Like
Reactions: WVI
abctrash
