From a Roadtrek 190 that was salvaged, same donor as my swivel seat bases.NICE DASH -THE WOOD TRIM!!
Do remember that his van is a 2000. I am not sure the contours are the same. I know the doghouse is much larger in the 2003 and up models.len, where did you order the carpet?
TK
Did you spring for the thicker pile or the upgraded backing material ?other than the fuse box the shape is the same. The underlayment/insulation cut outs are different for the difference in shifter cable and wire loom configuration/routing. In short, with some work, it can fit. I got it from: https://www.stockinteriors.com/AutoCarpet.asp?Itemid=20514&ModelId=750
It's not OEM quality, but, for the money it's fine.
I didn't, just the basic...it's plenty for what I wanted.Did you spring for the thicker pile or the upgraded backing material ?
