Gluing to plastic
Ducky's Dad
According to the stat sheet from innerduct it’s not all that strong but plenty strong for most applications. https://www.innerduct.com/hdpe-glue.
That's why screws are a good idea if you are going to mount hardware onto the Trex (or whatever) blocks inside the box. Screws from the outside into the back of the blocks will help keep them from coming loose offroad.
If you are glueing plastics it does help to heat it up first, scruff it up good and clamp.
With plastics, I always scrub with acetone, whether I'm gluing or just painting. Plastics have plasticizers in them, and those substances will often create a surface film that interferes with any kind of chemical or solvent bond. If you sand or scuff some plastics without cleaning, you just spread the stuff around.
s.e.charles
about 1:20 into this video, he mentions "Subaru molded plastic product" of which I have no clue of its properties.
Photobug
This dudes work is amazing. His craftsmanship in wood and wire, wow.
My only criticism is there is a lot of space taken up by electrical in a very small vehicle. I would love to see what he would do with a larger vehicle.
shade
It's Sugru, not Subaru. :)
I'm not sure how long it'll work on the roof rack like that, but it's ok stuff. I've seen DIY recipes for a similar product.
calicamper
I’ve found that wood in cars ie passenger space is not good. Even way back in the day Auto makers found that wood trim needed an aluminum backing to help reduce serious passenger injury from splintered wood trim in accidents.
project13support
